VLANs with Catalyst3560 and CE500
msubtain
I have 1 3560, which i am using as CORE SWITCH, my intension is to segment the users into different groups and then make VLANS on 3560, e.g MARKETING, FINANACE, ADMINISTRATION, PROJECTS, and so on, i have Cisco CE500 series switches (WS-CE500-24TT) as workgroup switches, what i want to do is to use the 10/100/1000 ports on these switches to plug into 3560's appropriate VLAN ports.
The problem i am facing is on 3560 i am getting message
"NATIVE_VLAN_MISMATCH: Native VLAN mismatch discovered on GigabitEt
hernet0/2 (12), with administration1 GigabitEthernet1 (1)"
on CE500, they have VLAN support in them, which i really dont want to use, all ports on them are part of management vlan 1 by default. so in this case the VLAN created on 3560 is MARKETING VLAN12 so i am getting NATIVE VLAN mismatch message.
Can i disable VLAN support on CE500? which i guess i can;t.
Switchport mode is Access on gig 0/2 (3560)
Can anyone throw some light on how to deal with the mentioned above situation.
thanks
15 Replies 15
thanks glen it solved the problem.
