WAAS Express problem
atiye.bigdeli
Beginner
Beginner
Hi friends
I want to deply WAAS_Express in 2901 router. according to cisco documents 2901 support the waas experss
but there no any licese for waas express.
so I buy the WAAS_Express license for 2901 and try to install that in the router, but the result shown that the license is not supportedWhatsApp Image 2018-08-12 at 1.49.44 PM.jpeg
what is the problem?
best regards.
Diana Karolina Rojas
Hello!
Can you provide your "show ver" output?
Best Regards,
there is no license for waas express even right to use.
best regards
the command result for "show license detail WAAS_Express" is empty.
and when I add the router to the waas manager, the status of router is pending
and in configuration detail panel the ssl has the problem.
this problem is for waas express license?
the security license is enabled.
best regards
Recognize Your Peers
