07-14-2004 08:56 PM - edited 03-02-2019 05:05 PM
Hi All,
I have a hub-spoke network of 55XX/6XXX series switches. From a single point I want to monitor every switche's CPU Utilization.
I checked one util called Getif. Any other (better) suggestions from the group.
Vijayendra K. S.
07-15-2004 03:21 AM
The Getif can't collect the catOS's cpu and you can serch on cisco web site.
IOS CPU oid:1.3.6.1.4.1.9.2.1.56
07-15-2004 06:10 AM
I like to use MRTG (http://people.ee.ethz.ch/~oetiker/webtools/mrtg/).
A couple of tricks for CPU utilization:
- Private MIB objects need a full specification (1.3.6.1.2....).
- Default scaling can be overridden with fixed scales (also useful
to prevent misleading usage graphs).
- Use the "gauge" option to plot value rather than change.
Here is a sample config for a 7206 router (watch the line wraps):
Target[gw.sample.net_cpu]: 1.3.6.1.4.1.9.9.109.1.1.1.1.5.1&1.3.6.1.4.1.9.9.109.1.1.1.1.5.1:public@gw.sample.net:
Options[gw.sample.net_cpu]: guage nopercent noo
MaxBytes[gw.sample.net_cpu]: 100
Unscaled[gw.sample.net_cpu]: dwmy
WithPeak[gw.sample.net_cpu]: wmy
YLegend[gw.sample.net_cpu]: CPU %
ShortLegend[gw.sample.net_cpu]:
Legend1[gw.sample.net_cpu]: 5 minute CPU Usage
Legend2[gw.sample.net_cpu]: 5 minute CPU Usage
Legend3[gw.sample.net_cpu]: Peak 5 minute CPU Usage
Legend4[gw.sample.net_cpu]: Peak 5 minute CPU Usage
LegendI[gw.sample.net_cpu]: CPU %
LegendO[gw.sample.net_cpu]: CPU %
Title[gw.sample.net_cpu]: CPU Utilization on gw.sample.net
PageTop[gw.sample.net_cpu]: PORTNAME
| System: | gw.sample.net in |
| Maintainer: |
Good luck and have fun!
Vincent C Jones
07-15-2004 05:50 AM
A great utility is called MRTG:
It's a great tool and provides a single web page where you can see all your graphs at once. It's a bit tricky to set up but there are lots of resources on the Internet that can be of assistance.
07-19-2004 05:12 AM
I confirm the (great!!) value of MRTG.
here are some further info from Cisco:
How to Collect CPU Utilization on Cisco IOS Devices Using SNMP:
http://www.cisco.com/en/US/tech/tk648/tk362/technologies_tech_note09186a0080094a94.shtml
