10-09-2002 06:47 PM - edited 03-02-2019 01:58 AM
Hi anyone, I have the following configurations and scenerio;
My HQ office is using a 2610 with two ethernet ports (10 BASET Half-Duplex);
eth0/0 - 210.188.31.84
eth0/1 - 210.188.6.1 - Internal LAN
From eth0/0, it's connected to the ethernet port of the Aironet Bridge 350 with ip address - 210.188.31.57. From this bridge, its disc shoots to another building with the root bridge of ip address 210.188.31.56. From there, it shoots back to our local ISP with gateway 210.188.31.5 for Internet Access.
The above configurations had been adopted for about 10 months, so fa so good but then since recently these two weeks, problems occur - the link to Internet (up to 210.188.31.5) up and down.
From my Internal LAN here, I can ping up to 210.188.31.57 (constantly NO timeout),but we I ping to 210.188.31.56, the link will up for about 2 minutes and then down for 20 secs and up again by itself.
I had been trying to change the Aironet bridge at both sides (210.188.31.56 & 210.188.31.57), the same thing happens.
Please suggest any solution to fix these problems.
Thank You.
10-10-2002 07:36 AM
Is it possible some one else in the regaion is using the same frequency (or channel close to yours) as you are?
Norman
10-10-2002 10:53 AM
You didn't say how often these link up/down conditions are occurring - try to pattern out the times of the day, and days of the week, in which these outages occur. Is there construction going on nearby? It could be interference somewhere close by as well as to the other suggestions about a neighboring bridge.
-Jeff
