11-01-2004 08:04 PM - edited 03-02-2019 07:40 PM
I believe there may be an incompatibility between the Cisco and the 3Com thats causing these issues.
When I ping from the 1711 I get the following whether or not we are in half duplex or full duplex or speed 10 or 100 mbps. Notice every third packet is dropped. If I source from the LAN 192.168.1.1 I can still ping and get the same problems. A user on the LAN from his workstation can only get to some of the IP's on the DMZ (63.145.181.64/27) see 2 Below he is unable to get a ping response from.
LAN Interface (VLAN1) 192.168.1.1/24
DMZ (VLAN2) 63.145.181.66/27
Internet 67.100.97.194/29
I have confirmed there is only one Default gateway on these devices. Some are dell servers and some are Cobalt raq3's and 4's.
LFL-1711-LAN#ping
Protocol [ip]:
Target IP address: 63.145.181.67
Repeat count [5]: 500
Datagram size [100]:
Timeout in seconds [2]:
Extended commands [n]:
Sweep range of sizes [n]:
Sending 500, 100-byte ICMP Echos to 63.145.181.67, timeout is 2 seconds:
Success rate is 67 percent (124/184), round-trip min/avg/max = 1/1/4 ms
LFL-1711-LAN#
Select menu option (physicalInterface/ethernet):
LFL-1711-LAN#ping
Protocol [ip]:
Target IP address: 63.145.181.89
Repeat count [5]: 5000
Sending 5000, 100-byte ICMP Echos to 63.145.181.89, timeout is 2 seconds:
Success rate is 59 percent (151/253), round-trip min/avg/max = 1/1/4 ms
ip subnet-zero
no ip domain lookup
ip domain name ****forless.com
ip dhcp excluded-address 192.168.1.1 192.168.1.20
ip dhcp pool 192.168.1.0/24
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
domain-name ****less.com
dns-server 63.147.112.162 !
ip cef
ip audit po max-events 100
no vlan accounting
no ftp-server write-enable
no crypto isakmp enable
interface FastEthernet0
description INTERNET
ip address 67.100.97.194 255.255.255.248
ip access-group Wan_2_Local in
ip nat outside
duplex auto
speed auto
no cdp enable
interface FastEthernet1
switchport access vlan 2
no ip address
duplex full
speed 100
no cdp enable
interface FastEthernet2
no ip address
duplex full
speed 100
no cdp enable
interface FastEthernet3
no ip address
duplex full
speed 100
no cdp enable
interface FastEthernet4
no ip address
duplex full
speed 100
no cdp enable
interface Vlan2
description DMZ
ip address 63.145.181.66 255.255.255.224
interface Vlan1
description $ETH-SW-LAUNCH$
ip nat inside
ip classless
ip route 0.0.0.0 0.0.0.0 67.100.97.193
ip nat inside source list NAT interface FastEthernet0 overload
ip access-list extended NAT
permit ip 192.168.1.0 0.0.0.255 any
ip access-list extended Wan_2_Local
permit tcp any any eq 22
line con 0
logging synchronous
transport preferred all
transport output all
line 1
stopbits 1
speed 115200
flowcontrol hardware
line aux 0
line vty 0 4
privilege level 15
password 123456
logging synchronous
login authentication ssh
transport input ssh
11-02-2004 12:01 AM
just some ideas:
1) Are you sure the bottleneck is your 1711?
Have you tried to ping form one DNS device to another device in DNS?
Isn't there the same problem?
If yes, what is the network device in DMZ? A hub or a cheap switch?
2)Do you see any interface errors on your 1711?
3)Does anything change if you extend the Ping packet size?
Milan
