2600 config problem
rodneyw
--begin ciscomoderator note-- The following post has been edited to remove potentially confidential information. Please refrain from posting confidential information on the site to reduce security risks to your network. -- end ciscomoderator note --
I'm a rookie and need help configuring a 2600 router.
Problem is I can only ping one subinterface which is 0/0.1 all others fail and I can't figure it out - The one that works is a 64k circuit all others are 256k Frame relay
Here's the config - TIA (Thanks in Advance)
Current configuration:
version 12.0
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname TestLab
no logging buffered
enable secret 5 --moderator edit--
memory-size iomem 15
ip subnet-zero
no ip domain-lookup
ip host Bonifay 192.168.1.2
ip host B-Town 192.168.2.2
ip host Marianna 192.168.3.2
ip host Chipley 192.168.5.2
interface FastEthernet0/0
ip address 16x.xx.xx.2 255.255.255.192
ip helper-address 16x.xx.xx.7
no ip directed-broadcast
duplex auto
speed auto
interface Serial0/0
bandwidth 1544
no ip address
encapsulation frame-relay IETF
no fair-queue
frame-relay lmi-type cisco
hold-queue 1024 out
interface Serial0/0.1 point-to-point
description To: Bonifay 64k circuit
frame-relay interface-dlci 20
interface Serial0/0.2 point-to-point
description To: Blountstown 256k circuit
ip address 192.168.2.1 255.255.255.0
frame-relay interface-dlci 19
interface Serial0/0.3 point-to-point
description To: Marianna 256k circuit
ip address 192.168.3.1 255.255.255.0
frame-relay interface-dlci 21
interface Serial0/0.4 point-to-point
description To: Chipley 256k circuit
ip address 192.168.5.1 255.255.255.0
frame-relay interface-dlci 22
interface FastEthernet0/1
ip address 192.168.20.1 255.255.255.0
duplex auto
speed auto
router eigrp 1
redistribute static
network 16x.xx.0.0
network 192.168.1.0
network 192.168.2.0
network 192.168.3.0
network 192.168.5.0
distribute-list 1 out FastEthernet0/0
ip classless
ip route 0.0.0.0 0.0.0.0 16x.xx.xx.1
ip route 16x.xx.x.0 255.255.0.0 16x.xx.xx.0
ip route 16x.xx.xx.64 255.255.255.192 192.168.5.2
ip route 16x.xx.xx.192 255.255.255.192 192.168.3.2
ip route 16x.xx.xx.224 255.255.255.240 192.168.1.2
ip route 16x.xx.xx.128 255.255.255.192 192.168.2.2
no ip http server
access-list 1 permit 16x.xx.xx.0 0.0.0.255
access-list 1 deny any
banner motd ^C
This ROUTER belongs to the CHIPOLA REGIONAL WORKFORCE and ONLY
AUTHORIZED CHIPOLA REGIONAL WORKFORCE EMPLOYEES are ALLOWED ACCESS
ALL OTHERS ARE DENIED ACCESS
^C
line con 0
timeout login response 20
password xxxxx
logging synchronous
login
transport input none
line aux 0
line vty 0 4
password xxxxx
login
no scheduler allocate
end
11 Replies 11
deilert
Level 6
Level 6
where are you trying to ping from ?
can you paste in a sh ip route and a sh frame-relay pvc
+ add a show ip int brief.
Sorry I cant do this online at this time-in production between 8-5 have to test after hours but here's offline info if it helps
TestLab#sh ip int brief
Interface IP-Address OK? Method Status Prot
ocol
FastEthernet0/0 164.51.32.2 YES NVRAM up down
Serial0/0 unassigned YES NVRAM administratively down down
Serial0/0.1 192.168.1.1 YES NVRAM down down
Serial0/0.2 192.168.2.1 YES NVRAM down down
Serial0/0.3 192.168.3.1 YES NVRAM down down
Serial0/0.4 192.168.5.1 YES NVRAM down down
FastEthernet0/1 192.168.20.1 YES NVRAM up down
Your serial0/0 interface is administratively down, use a "no shutdown" under serial 0/0 interface. That should help.
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
It is down now because I had to take the router off line during production hours - When I have it online all serial interfaces including all subinterfaces show up and protocol up.
I cant connect the serial up during production time so there are no routes now I will get them tomorrow am. but here's the pvc's
PVC Statistics for interface Serial0/0 (Frame Relay DTE)
Active Inactive Deleted Static
Local 0 0 4 0
Switched 0 0 0 0
Unused 0 0 0 0
DLCI = 19, DLCI USAGE = LOCAL, PVC STATUS = DELETED, INTERFACE = Serial0/0.2
input pkts 0 output pkts 0 in bytes 0
out bytes 0 dropped pkts 0 in FECN pkts 0
in BECN pkts 0 out FECN pkts 0 out BECN pkts 0
in DE pkts 0 out DE pkts 0
out bcast pkts 0 out bcast bytes 0
pvc create time 01:30:39, last time pvc status changed 01:30:38
DLCI = 20, DLCI USAGE = LOCAL, PVC STATUS = DELETED, INTERFACE = Serial0/0.1
pvc create time 01:30:44, last time pvc status changed 01:30:43
DLCI = 21, DLCI USAGE = LOCAL, PVC STATUS = DELETED, INTERFACE = Serial0/0.3
pvc create time 01:30:45, last time pvc status changed 01:30:44
DLCI = 22, DLCI USAGE = LOCAL, PVC STATUS = DELETED, INTERFACE = Serial0/0.4
pvc create time 01:30:46, last time pvc status changed 01:30:45
TestLab#
When online all show status as active
I'm pinging from the console of the 2600 that I'm trying to configure. I can ping subinterface 192.168.1.1 and the other end far router 192.168.1.2 I can not ping any other subinterface either end.
thisisshanky
Level 11
Level 11
What does a "show frame-relay map" on this router looks like? Are you getting a map entry for each of the above point to point sub interfaces ?
a sample should like this for each subinterface
show frame map
Serial0.1 (up): point-to-point dlci, dlci101(0x65,0x1850), broadcast
Sankar Nair
Here's a copy off line - when online all show up
TestLab#show frame map
Serial0/0.1 (down): point-to-point dlci, dlci 20(0x14,0x440), broadcast
status deleted
Serial0/0.3 (down): point-to-point dlci, dlci 21(0x15,0x450), broadcast
status deleted
Serial0/0.2 (down): point-to-point dlci, dlci 19(0x13,0x430), broadcast
status deleted
Serial0/0.4 (down): point-to-point dlci, dlci 22(0x16,0x460), broadcast
status deleted
TestLab#
The show frame-relay pvc command is showing pvc as "deleted".
Does this show as deleted even when the router is online??
If its showing as deleted, then you might have to contact your frame-relay service provider.
-Deepu
No when online it shows as active
