12-08-2004 05:26 PM - edited 03-02-2019 08:28 PM
Anyone expirience this before?
I have 60 users accessing the internet using 2611 router. Everytime when user start to use Bittorrent, the CPU utilisation will shoot up to 95% and then the router will hang. No traffic will go through and the console is not responding as well.
I've tried to block Bittorrent default ports but it is not efficient.
Any suggestions on this issue?
12-09-2004 02:19 AM
For suggestions we need more information on the config of your router.
More info for you can be found:
http://www.cisco.com/en/US/products/hw/routers/ps133/products_tech_note09186a00800a70f2.shtml
12-09-2004 03:23 PM
If you are still having this problem, can you post your configuration.
Daniel
12-29-2004 07:10 AM
I suggest to use a policy map to drop all P2P file sharing programs. ex
class-map match-any p2p
match protocol fasttrack
match protocol gnutella
match protocol napster
match protocol kazaa2
match protocol edonkey
match protocol winmx
match protocol bittorrent
policy-map block-p2p
class p2p
drop
service-policy input block-p2p (place on internet facing interface)
12-29-2004 07:15 AM
I would also look at blocking that traffic.
12-29-2004 07:46 AM
You could also load the NBAR PDLM for bittorent to help it match the traffic.
01-03-2005 01:00 PM
Question on the correct syntax:
My routers (Version 12.3(8)T4) were configured with:
match protocol fasttrack file-transfer "*"
match protocol gnutella file-transfer "*"
match protocol kazaa2 file-transfer "*"
instead of:
match protocol fasttrack file-transfer *
match protocol gnutella file-transfer *
match protocol kazaa2 file-transfer *
OR your example of:
Is there a difference?
Lloyd
