03-02-2006 06:49 AM - edited 03-03-2019 02:05 AM
This is a truly odd situation, I have a 2950 running IOS version 12.1(22)EA4 and I have set up probably hundreds of Layer 2 switches, and I set interface vlan to a static ip within 24 hours it changes itself to a dhcp ip address. I thought someone was messing with me at first so I locked it down hardcore but yet it still changes to dhcp. There are no funky service commands on the switch. Anybody got a clue on this one?
03-02-2006 07:41 AM
Unless you have some sort of dhcp setup on the switch I don't see how thats possible without intervention . If the switch was setup to pull it address from somewhere else and you had a link go down or soemthing it might pull another address . Maybe if you post the switch config .
03-02-2006 10:45 AM
Sanitized Config as requested:
Current configuration : 1285 bytes
version 12.1
no service pad
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname Beijing-2950
enable secret xxxxxxxxxxxxxxxxxxx
ip subnet-zero
spanning-tree mode pvst
no spanning-tree optimize bpdu transmission
interface FastEthernet0/1
interface FastEthernet0/2
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface Vlan1
ip address xxx.xx.140.250 255.255.255.0
no ip route-cache
ip default-gateway xxx.xx.140.249
ip http server
line con 0
password xxxxxxxxxxxx
login
line vty 0 4
login
line vty 5 15
password xxxxxxxxxxxxx
login
end
03-02-2006 10:55 AM
Don't see anything there , don't see how it would be possible for it to change . How do you know it is changing ? Someone else would have to know the passwords and manually change it . I see you have "ip http server " enabled , if you don't need it get rid of it .
03-02-2006 11:28 AM
I know it's changing because I monitor it via IP
I have DHCP running on a 3560 and I can see that the IP it is getting is in the scope and bound to this switch. Very funky huh. I am going to upgrade the version of IOS and see if that fixes it. If not I am swapping that switch out. Thanks for sanity check.
-Ken
03-14-2006 09:42 AM
Code upgrade fixed this situation in case anyone is curious.
