12-02-2004 01:36 PM - edited 03-02-2019 08:22 PM
Greetings all
I have two new 3550-12g running 12.1(19)EA1c IOS.
I am trying to connect both switches using inbuilt
RJ45 10/100/1000 port (# 11, 12). The trunk works fine
if i use 100Mbps connection crossover cable. The same does not work with 1000mbps.
Am I missing something ?
thx
Ajit
12-02-2004 01:43 PM
Are the links set to auto or hardcoded to 100 Mbps ?
Have you checked your gigabit crossover cable to see if its crossed properly ? Gigabit uses all 4 pairs.
12-02-2004 02:00 PM
Well If I hardcode the speed at 100Mbps it works.
If I use straighthrough cable with speed/duplex auto
(default config) why It's not autonegotiating to 1000Mbps ? you are right I might have to use different
crossover for gigabit.
thx
12-02-2004 02:13 PM
Hope this post helps
You have to use a diff cross over to work at 1000 Mbps. At 100 Mbps it uses only 2 pairs. At 1000 Mbps all 4 pairs are used.
