1183
Highlighted
Beginner
3550 interface MTU
hello netpro:
I have a simple question, how to modify the mtu on 3550 ,the version is c3550-i5q3l2-mz.121-20.EA1, thank you
1 ACCEPTED SOLUTION
Highlighted
Re: 3550 interface MTU
Hi Yan,
Gigabit Ethernet versions support up to 2000 bytes and the Fast Ethernet versions support up to 1546 bytes.
from a gig switch:
3550(config)#system mtu ?
<1500-2000> MTU size in bytes
3550(config)#system mtu 2000
Changes to the System MTU will not take effect until the next reload is done.
Refer for more details:
http://www.cisco.com/en/US/partner/products/hw/switches/ps700/products_configuration_example09186a008010edab.shtml#c4
Please rate post as applicable.
2 REPLIES 2
Highlighted
Hi Yan,
from a gig switch:
Highlighted
Enthusiast
as said Rajat, please pay attention: on 3550 you could configure the "system" mtu, and not for a specific interface.
Andrea
