3750 problem
ciscoforum
I noticed when I show run for WS-C3750G-24TS-E, it shows 3/0/x for the ports, not 1/0/x, This is a standalone switch now. But it was used in the lab stacked with the other switches.( I think maybe when they remove it from the stack it was not powered down before disconnect). Anyway now I want to recover it to the default configration. I even erased the config, but still same. I noticed there is a global command:switch 3 provision.. I tried to remove it by "no" but it says "DBI" can't be removed while it is active. How can I make the show running looks like inter giga 1/0/x not 3/1/x any more?
ybajpai
In global config, try "switch 3 renumber 1". save the config and reload the switch and you should have the ports as 1/0/x.
Please see below for more information:
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat3750/12225sea/3750scg/swstack.htm#wp1112897
(URL may have word wraps)
Thanks. It works. Great
