Join Customer Connection to register!
560
williamsilva7
Beginner
4500 Series Switches and 802.1x MAB
My organization has multiple 4500 series switches experiencing the same problem when attempting to authenticate devices via MAB.  The issue is that the "show mab interface fax/x details" shows the Client MAC in a waiting status.  The device is never sending the switch it's MAC in order to proceed with MAB authentication, so of course the port never forwards traffic.  However, if we remove authentication port-control auto the port starts forwarding and the device gains connectivity.  Below is the interface configuration command and the MAB details.  The IOS version of this current switch is 15.0(2)SG8.  Are we missing something special for a 4500 as far as configuration is concerned.
interface FastEthernet8/16
 description USER
 switchport access vlan 600
 switchport mode access
 switchport nonegotiate
 duplex full
 authentication host-mode multi-domain
 authentication periodic
 mab
 dot1x pae authenticator
 dot1x timeout tx-period 5
end
SWITCH-4510R#sh mab interface fa8/16 details
MAB details for FastEthernet8/16
Mac-Auth-Bypass           = Enabled
MAB Client List
Client MAC                = Waiting
Session ID                = 841AF6D100002931AF99B827
MAB SM state              = ACQUIRING
Auth Status               = UNAUTHORIZED
5 REPLIES 5
Lee Valentin
Beginner
What's the order of authentication?
authentication order <mab | dot1x | webauth>
Good luck
I've tried with authentication order mab or the default which I believe is dot1x still get he same results.
Post your configs.
aaronhighfill
Beginner
You might look into "authentication control-direction in".
I've had good luck with it in this type of scenario. If I'm understanding correctly.
Tiago Marques
Beginner
hello,
in my organization we have multiple 3560/2960 series switches and some 4500 with MAB.
the interfaces have the following config:
 authentication host-mode multi-auth
 authentication order mab dot1x
 authentication priority mab dot1x
 authentication timer restart 120
 authentication timer reauthenticate server
 authentication timer inactivity 600
 mab
Good luck
Content for Community-Ad
