04-17-2005 08:38 PM - edited 03-02-2019 10:29 PM
* Welcome to Rom Monitor for WS-X4515 System. *
* Copyright (c) 2002 by Cisco Systems, Inc. *
* All rights reserved. *
Rom Monitor Program Version 12.1(12r)EW
Board type 2, Board revision 7
Swamp FPGA revision 28, Dagobah FPGA revision 86
MAC Address : 00-0c-85-95-8a-01
Ip Address : Not set.
Netmask : Not set.
Gateway : Not set.
TftpServer : Not set.
Main Memory : 512 MBytes
***** The system will autoboot in 5 seconds *****
Type control-C to prevent autobooting.
******** The system will autoboot now ********
config-register = 0x2102
Autobooting using BOOT variable specified file.....
Current BOOT file is --- bootflash:cat4000-i9s-mz.121-19.EW1.bin
Rommon reg: 0x56004380
Running diags...
Decompressing the image
############################################### [OK]
Unmatched right bracket at /tmp/Exporter.pm line 5, at end of line
syntax error at /tmp/Exporter.pm line 5, near "}"
BEGIN failed--compilation aborted at /tmp/HalLib.pm line 12.
Netmask : Not set.
Gateway : Not set.
Running diags...
04-17-2005 10:51 PM
You did not state wheter the problem arose out of the blue or after an upgrade. There are several options:
1: Insuffucient RAM to run this image.
2: Corrupted image in flash
3: Hardware problems.
To alleviate the problem, verify your system requirements, eventually re-enter the image in flash or .. feel free to post additional info when it does not work out.
Leo
