518
danielbarri
Beginner
6500 CAT-OS static CAM entries
I have two 6500 connected to each other with ether-channel(lacp). I have no configured any static cam entries. But when doing "show cam stat" one of 6500 shows:
SEORBB0001> (enable) sh cam stat
* = Static Entry. + = Permanent Entry. # = System Entry. R = Router Entry.
X = Port Security Entry $ = Dot1x Security Entry
VLAN Dest MAC/Route Des [CoS] Destination Ports or VCs / [Protocol Type]
5 01-00-5e-50-44-53 2/36,4/36,9/8,9/13-16
5 01-00-5e-7f-ff-fa 2/36,4/36,9/8,9/13-16
6 01-00-5e-50-44-53 2/36,4/36,9/13-16
6 01-00-5e-7f-ff-fa 2/36,4/36,9/13-16
110 01-00-5e-50-44-53 2/39,4/39
Total Matching CAM Entries Displayed =5
and the second one shows:
SEORBB0002> (enable) sh cam stat
5 01-00-5e-50-44-53 2/36,4/36,9/10,9/13-16
5 01-00-5e-7f-ff-fa 2/36,4/36,9/10,9/13-16
6 01-00-5e-50-44-53 9/8
6 01-00-5e-7f-ff-fa 9/8
Total Matching CAM Entries Displayed =4
My question is what is these mac addresses for?
It seems to be some kind of loop, since both switches point to each other in order to switch a frame, for example,to the destination mac 01-00-5e-50-44-53
5 REPLIES 5
Prashanth Krishnappa
If you have multicasting configured in your network, a multicast enabled router or an IGMP querier will install static CAM in your switch.
multicast is not enabled nor in the switches neither in the routers.
SEORBR0002#sh ip mroute
IP Multicast Forwarding is not enabled.
SEORBB0002> (enable) sh igmp querier information
IGMP switch querier disabled for all VLAN(s)
Can you do a "sh multicast group" and a " sh multicast router" on the switch
SEORBB0001> (enable) sho multicast group
5 01-00-5e-7f-ff-fa 9/8,9/13-16
6 01-00-5e-7f-ff-fa 9/13-16
112 01-00-5e-7f-ff-fe 9/13-16
Total Number of Entries = 4
SEORBB0001> (enable) sho multicast router
Port Vlan
Total Number of Entries = 0
'*' - Configured
'+' - RGMP-capable
'#' - Channeled Port
'$' - IGMP-V3 Router
'@' - IGMP-Querier Router
There is some multicast application in your network. Use a sniffer to determine what it is
