09-26-2016 11:40 AM - edited 03-03-2019 08:21 AM
It is necessary to create a Link Aggregation between Cisco6509 in DELL PowerConnect 6224F (two SFP ports on each side).
Module 2 picks up the link and operating normally.
Module 6 - after a few seconds, completely switched off and only starts after removal and re-installation in the chassis.
At Dell uses the same ports.
Cisco log:
%PM_SCP-SP-2-LCP_FW_ERR_INFORM: Module 6 is experiencing the following error: Interrupt counters cumulative, (10s critical/noncritical): ROINT[0]: totalcalls=1, aricjacrc=1. ROINT[1]: totalcalls=1152, p2aecc1=184, p2necc1=6, ecc2=521, pb2arinterm=905, (870/182). ROINT[2]: totalcalls=1, aricjacrc=1.
%PM_SCP-SP-1-LCP_FW_ERR_POWERDOWN: Module 6 will be powered down due to firmware error: RO[1] (870 critical int in the last 10s).
Cisco Module 2 port-channel config
interface Port-channel1
switchport
switchport trunk allowed vlan 526,530
switchport mode trunk
switchport nonegotiate
no ip address
interface GigabitEthernet2/47
switchport
no ip address
channel-group 1 mode on
interface GigabitEthernet2/48
switchport
no ip address
Cisco Module 6 port-channel config
interface Port-channel8
switchport
no ip address
interface GigabitEthernet6/47
switchport
no ip address
channel-group 8 mode on
interface GigabitEthernet6/48
switchport
no ip address
Module info
Mod Port Model Serial # Versions
1 ---
2 48 WS-X6748-SFP Hw : 1.8
Fw : 12.2(14r)S5
Sw : 12.2(18)SXF7
Sw1: 8.6(0.306)R3V7
WS-F6700-CFC Hw : 4.0
3 ---
5 ---
6 48 WS-X6748-SFP Hw : 1.8
Fw : 12.2(18r)S1
Sw : 12.2(18)SXF7
Sw1: 8.6(0.306)R3V7
WS-F6700-DFC3B Hw : 4.6
#sh ver
IOS (tm) s72033_rp Software (s72033_rp-ADVIPSERVICESK9_WAN-M), Version 12.2(18)SXF7, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2006 by cisco Systems, Inc.
Compiled Thu 23-Nov-06 06:00 by kellythw
Image text-base: 0x40101040, data-base: 0x42D98000
ROM: System Bootstrap, Version 12.2(17r)SX5, RELEASE SOFTWARE (fc1)
BOOTLDR: s72033_rp Software (s72033_rp-ADVIPSERVICESK9_WAN-M), Version 12.2(18)SXF7, RELEASE SOFTWARE (fc1)
cisco WS-C6509-E (R7000) processor (revision 1.4) with 983008K/65536K bytes of memory.
Processor board ID SMG1132N5F5
SR71000 CPU at 600Mhz, Implementation 0x504, Rev 1.2, 512KB L2 Cache
Last reset from s/w reset
SuperLAT software (copyright 1990 by Meridian Technology Corp).
X.25 software, Version 3.0.0.
Bridging software.
TN3270 Emulation software.
323 Virtual Ethernet/IEEE 802.3 interfaces
146 Gigabit Ethernet/IEEE 802.3 interfaces
4 Ten Gigabit Ethernet/IEEE 802.3 interfaces
1917K bytes of non-volatile configuration memory.
8192K bytes of packet buffer memory.
09-26-2016 07:54 PM
Either RMA module 6 line card or upgrade the firmware. This error message tells me the firmware in the line card is corrupted.
09-27-2016 12:17 AM
Hello, Leo!
Thank you very much for your response.
Can you help me with the upgrade.
Is it necessary to update the chassis firmware or module 6 firmware only?
Where can I find a description of the update procedure and firmware files?
09-27-2016 05:21 AM
Upgrade the IOS of the chassis/supervisor card and that same IOS will load the firmware into each line card.
There are several methods of upgrading the IOS of a chassis and instructions for each method can be found in the Release Notes.
