06-27-2012 03:47 AM - edited 03-03-2019 06:39 AM
L2switch and PC are connected to Catalyst2960S with Cate5 (2pair).
NIC of L2switch or PC corresponds to 10/100/1000BASE-T.
2960S,L2switch, and PC are auto negotiation.
Although the connection state of L2switch is linkdown,
the connection state of PC is linkup (100BASE-TX).
Why does L2switch is linkdown?
06-27-2012 04:08 AM
Can you post the show run for that interface
And show interface?
06-27-2012 08:08 PM
hi,
Thanks for your reply.
----Port connected L2Switch ---
Cat2960S#show int gi1/0/15
GigabitEthernet1/0/15 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet, address is
MTU 1500 bytes, BW 10000 Kbit/sec, DLY 1000 usec,
Keepalive set (10 sec)
Auto-duplex, Auto-speed, media type is 10/100/1000BaseTX
input flow-control is off, output flow-control is unsupported
Last input never, output never, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts (0 multicasts)
0 watchdog, 0 multicast, 0 pause input
0 packets output, 0 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
0 unknown protocol drops
0 lost carrier, 0 no carrier, 0 pause output
Cat2960S#
Cat2960S#show run int gi1/0/15
Building configuration...
interface GigabitEthernet1/0/15
end
Cat2960S#
----Port connected PC---
Cat2960S#show int gi1/0/9
GigabitEthernet1/0/9 is up, line protocol is up (connected)
MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
Full-duplex, 100Mb/s, media type is 10/100/1000BaseTX
Last input never, output 00:00:06, output hang never
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 670
5 minute output rate 5000 bits/sec, 2 packets/sec
4083535 packets input, 835231693 bytes, 0 no buffer
Received 20129 broadcasts (605 multicasts)
1 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
0 watchdog, 605 multicast, 0 pause input
16042859 packets output, 8298142862 bytes, 0 underruns
Cat2960S#
Cat2960S#show run int gi1/0/9
interface GigabitEthernet1/0/9
end
Cat2960S#
06-28-2012 01:12 AM
hi,
base on that info,
and the input/output counter of packet/frame which all zero.
it behaves like you dont connect the cable to this port or using wrong type of cable or using bad cable.
what kind of cable do you use for connecting between the switch?
if both switch have auto mdi/mdix feature then it doesnt matter wether you using straight or cross cable.
regards,
06-28-2012 04:48 PM
Kindly do the following commands:
1. test cab tdr int gi1/0/15;
2. Wait for approximately 5 to 7 seconds;
3. sh cable tdr int gi1/0/15; and
4. Please post the output.
06-28-2012 09:54 AM
With only a 2 pair cable u could get Trouble with mdi/mdix..Try a Cross cable and if that does Not help Try also to fix Speed and Duplex
Sebastian
