03-24-2020 08:20 AM - edited 03-25-2020 02:30 AM
I am trying to build an ADSL lab. I have attached my planned ADSL config for the remote\client router. My aim is to use either GNS3 or VIRL.
Is there a way to create a genuine ADSL network using simulated hardware or is an ADSL line from a Provider required?
03-25-2020 03:19 AM
You could make use of Cisco routers with ATM interfaces and an ATM switch for the ISP/transport part. I've done this some year ago and it worked with no problems. See here an example.
Cristian Matei.
03-26-2020 10:14 AM
I'm trying to simulate a "standard" ADSL configuration based on a Cisco 927, this will be my live environment.
The connection to the ISP will be ATM and that is what I'm trying to simulate i.e a single router with a direct ADSl connection to the ISP and ethernet on its LAN side.
03-25-2020 11:09 AM
03-26-2020 10:21 AM
Interesting however i'm trying to replicate a live Prod solution which will have an ATM interface on the client router.
Cheers
04-07-2020 07:07 AM
04-08-2020 07:39 AM
04-14-2020 02:10 AM
Thanks for that Cristian,
However I get an error when I click on it,
Forbidden
An error occurred. Please contact your System Administrator.
04-14-2020 02:33 AM
Hi Cristian,
I have now managed to get into that document.
That document however outlines how to configure an ADSL router to connect to an ISP, I'm trying to simulate the termination\connection of the ADSL line into an ISP.
I suppose you could say that I am trying to achieve two things,
1) configure the two devices connected to an ADSL line.
2) set-up one as a remote ADSL client route, and the second as the ISP\Server ADSL router.
(I am using GNS3 and specifically the ATM switch built into it.
Brian
