ASR1001-X Multi-chassis LAG support
SAC
Does ASR1001-X with IOS-XE 3.13S3 supports Multi-Chassis LAG?
johnnylingo
Level 5
Level 5
By themselves, no.  But if the neighboring device does (Nexus VPC, VSS, switch stack, etc) then they can do a port channel bundle.
Thanks Johnny. Any idea if the limitation is on the code and there are plans in future to add this feature or some sort of hardware limitations? Any link/doc which can provide details.
I'm definitely not the best person to ask as I don't work for Cisco and have zero hands-on experience with the ASR platform.  Lack of LAG support was the main reason I'm still using 6500s w/ VSS for edge routing.
