ATM DSL Diagnosis Help
I have been tasked with trying to discover what is wrong with our current adsl connection. I have issued the show dsl interface atm command and made good progress in understanding the meaning of the output. (I would gladly share my findings by way of a spreadsheet.)
But I need an expert to cast their eye over the output to tell me if it is 'bad' or 'good'. Our router is a Cisco 2800 with four atm ports. We are in the UK.
It is my understanding that the line from the exchange to our building is quite long and the connection between the wall and the router is over 4 metres.
I also noticed a couple of LOM defects on atm0/0/0 and atm0/2/0.
Thank you in advance.
ATM0/0/0
Alcatel 20150 chipset information
                ATU-R (DS)                      ATU-C (US)
Modem Status:    Showtime (DMTDSL_SHOWTIME)
DSL Mode:        ITU G.992.1 (G.DMT) Annex A
ITU STD NUM:     0x01                            0x1
Vendor ID:       '    '                          'TSTC'
Vendor Specific: 0xDBB0                          0x0000
Vendor Country:  0x04                            0xB5
Capacity Used:   100%                            97%
Noise Margin:    -2.5 dB                          7.0 dB
Output Power:    20.0 dBm                        12.0 dBm
Attenuation:     47.0 dB                         25.0 dB
FEC ES Errors:    0                               0
ES Errors:       939989                          36
SES Errors:       0                               0
LOSES Errors:     0                               0
UES Errors:       0                               0
Defect Status:                       LOM     None
Last Fail Code:  None
Watchdog Counter: 0x40
Watchdog Resets: 0
Selftest Result: 0x00
Subfunction:     0x15
Interrupts:      2654 (1 spurious)
PHY Access Err:  0
Activations:     2
LED Status:      ON
LED On Time:     100
LED Off Time:    100
Init FW:         ASW_init_3_8_131.bin
Operation FW:    ASW_R3_8_131.bin
FW Source:       embedded
FW Version:      3.8.131
                 Interleave             Fast    Interleave              Fast
Speed (kbps):          6720                0           768                 0
Cells:            200940294                0    1084868157                 0
Reed-Solomon EC:      32801                0           529                 1
CRC Errors:            3612                0            81                 1
Header Errors:        54955                0            62                 1
Bit Errors:               0                0
BER Valid sec:            0                0
BER Invalid sec:          0                0
LOM Monitoring : Disabled
DMT Bits Per Bin
000: 0 0 0 0 0 0 0 8 7 9 B B C C C C
010: C B B B B B B A A 9 9 8 8 6 0 0
020: 0 0 0 0 0 0 6 6 6 7 8 8 9 9 9 A
030: A B B C C C C D D D D D D E E E
040: 0 E 2 E E E E E D E E D D D D D
050: D D D D D D D D D D D D D D D D
060: D C D D D D D D D D D D D D D B
070: C C C D D C C C C C C C C A C C
080: C C C C C B B B B B B 9 B B B B
090: B B B B A A A A A 9 A A 9 9 9 9
0A0: A A A 9 A A 9 8 9 9 9 9 9 9 9 9
0B0: 9 9 8 8 8 7 8 8 8 8 9 8 8 8 8 6
0C0: 6 6 5 5 5 5 5 5 5 5 5 5 5 5 5 5
0D0: 5 5 5 5 5 5 5 5 5 4 5 4 4 4 4 3
0E0: 3 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4
0F0: 4 4 3 3 2 0 0 0 0 0 0 0 0 0 0 0
DSL: Training log buffer capability is not enabled
GLASAIRA#
show dsl interface atm 0/1/0
ATM0/1/0
Capacity Used:   100%                            98%
Noise Margin:     5.0 dB                          7.0 dB
Attenuation:     49.0 dB                         25.5 dB
FEC ES Errors:    0                               0
ES Errors:       940268                          36
SES Errors:       0                               0
LOSES Errors:     0                               0
UES Errors:       0                               0
Defect Status:   None                            None
Watchdog Counter: 0xF6
Watchdog Resets: 0
Subfunction:     0x15
Interrupts:      2654 (0 spurious)
PHY Access Err:  0
Activations:     2
LED Status:      ON
LED On Time:     100
LED Off Time:    100
FW Source:       embedded
FW Version:      3.8.131
Speed (kbps):          6400                0           704                 0
Cells:            201004196                0     994723430                 0
Reed-Solomon EC:      43150                0           480                 1
CRC Errors:             145                0             9                 1
Header Errors:          133                0             4                 1
Bit Errors:               0                0
BER Valid sec:            0                0
DMT Bits Per Bin
000: 0 0 0 0 0 0 0 8 8 9 9 B B B B 9
010: 6 8 B B B B B A A 9 9 9 7 6 0 0
020: 0 0 0 0 0 0 5 6 7 7 8 8 9 9 9 A
030: A B B B C C C C C C C C C C C D
040: 0 D D 2 D D D D D D C C C C C C
050: C C C C C C C C C C C C C C C C
060: C C C C C C C C C C C C C C C B
070: C B C B B B B B B B B B B B B B
080: B B B B B B B B B B B A A B A A
090: A A A A A A A A A A A A A A A A
0A0: A 9 A 9 9 9 9 9 9 9 9 9 9 9 9 9
0B0: 9 9 9 9 9 9 9 9 8 8 8 8 4 8 8 6
0C0: 6 6 6 6 5 6 6 5 5 5 5 5 5 5 5 5
0D0: 5 5 4 2 4 4 4 4 4 4 4 4 4 4 4 4
0E0: 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4
0F0: 3 4 3 3 3 0 0 0 0 0 0 0 0 0 0 0
GLASAIRA#show dsl interface atm 0/2/0
ATM0/2/0
Capacity Used:   99%                             98%
Noise Margin:    -1.0 dB                          6.0 dB
Attenuation:     48.0 dB                         25.0 dB
FEC ES Errors:    0                               0
ES Errors:       940292                          36
SES Errors:       0                               0
LOSES Errors:     0                               0
UES Errors:       0                               0
Watchdog Counter: 0xFF
Watchdog Resets: 0
Subfunction:     0x15
PHY Access Err:  0
Activations:     2
LED Status:      ON
LED On Time:     100
LED Off Time:    100
FW Source:       embedded
FW Version:      3.8.131
Speed (kbps):          6752                0           800                 0
Cells:            200915940                0    1130423255                 0
Reed-Solomon EC:      34540                0           696                 2
CRC Errors:            7796                0             5                 3
Header Errors:         5985                0             4                 1
Bit Errors:               0                0
BER Valid sec:            0                0
DMT Bits Per Bin
000: 0 0 0 0 0 0 0 8 8 9 B B C C C C
010: C C C C B B B B A A 9 9 8 7 0 0
020: 0 0 0 0 0 0 4 4 5 5 6 7 7 7 8 8
030: 9 9 A A B B B C C C D D D D E E
040: 0 E E E E D D 2 E E E E E E E E
050: E E E E E E E E E E E E E C D B
060: D 6 E E E D E E E E E D D D D B
070: D D D D D D D D D D D D D 9 C C
080: D D D D C C C C C B C 8 B A A B
090: C B B B A A A B A 6 A A 9 A A A
0A0: A A A 9 9 A 8 6 9 A A A 9 9 9 9
0B0: 9 9 9 9 8 6 8 8 8 8 8 8 7 8 7 6
0C0: 6 6 4 4 2 2 2 4 5 5 5 5 5 5 6 6
0D0: 5 5 5 4 5 5 5 5 5 5 5 5 5 5 5 5
0E0: 5 5 5 4 5 4 5 5 4 4 4 4 4 4 4 4
0F0: 4 4 4 4 4 0 0 0 0 0 0 0 0 0 0 0
GLASAIRA#show dsl interface atm 0/3/0
ATM0/3/0
Capacity Used:   100%                            99%
Noise Margin:     3.0 dB                          6.0 dB
Attenuation:     48.0 dB                         26.0 dB
FEC ES Errors:    0                               0
ES Errors:       940333                          36
SES Errors:       0                               0
LOSES Errors:     0                               0
UES Errors:       0                               0
Watchdog Counter: 0x1D
Watchdog Resets: 0
Subfunction:     0x15
PHY Access Err:  0
Activations:     2
LED Status:      ON
LED On Time:     100
LED Off Time:    100
FW Source:       embedded
FW Version:      3.8.131
Speed (kbps):          6144                0           704                 0
Cells:            201014958                0     994786830                 0
Reed-Solomon EC:      42151                0          1388                 4
CRC Errors:             380                0            73                 3
Header Errors:          338                0            55                 0
Bit Errors:               0                0
BER Valid sec:            0                0
DMT Bits Per Bin
000: 0 0 0 0 0 0 0 8 7 9 A B B B B A
010: 8 6 8 A B B B B B A 9 9 7 6 0 0
020: 0 0 0 0 0 0 5 6 7 7 8 8 9 9 9 9
030: A A A B B B B B B B B B C C C C
040: 0 B B C B B B 2 C B C C B B B B
050: B B B B B B B B B B B B B B B B
060: B B B B B B B B B B B B B B B B
070: B B B B B B B B B B B B B A B B
080: B B B B B B B A A A A 9 A A A A
090: A A A A A A A A A 9 A A 9 A A 9
0A0: 9 9 9 9 9 9 9 9 9 9 9 9 9 9 9 9
0B0: 9 9 9 9 9 8 9 9 8 8 8 7 4 7 8 6
0C0: 4 6 6 6 6 6 6 6 6 6 6 6 5 5 5 5
0D0: 5 5 4 2 4 5 5 5 5 5 5 5 5 4 4 4
0F0: 4 4 4 3 3 0 0 0 0 0 0 0 0 0 0 0
paolo bevilacqua
Seems good. It showsyou're far away from CO with all the consequences.
Paolo,
Thank you. Am I correct in thinking that the attenuation values are a good indication of line length? Also is a negative noise margin value an indication that the ratio of signal strength to noise is bad for our connection?
I am having problems discovering the formula that is used to determine values and also what the optimal values should be. For example, looking at the attentuation, output power and noise margin values, is there a way of determining what is an 'acceptable/correct/expected' amount of crc/es/header errors?
Thanks once again in advance for your help,
David
Negative noise margine is certainly a bad thing, I didn't had noticed and had never saw one before.
I don't have these formulas and I'm not sure if they even exists.
You can try updating ADSL firmware or the entire IOS (search), and get some improvement.
Alternatively see if you can get telco in switching you to a better pair, they can do good when they really want.
