ATM/Frame Relay Internetworking - How do I monitor for loss of PVC?
miyork
I have 2 7513's in my core with ATM DS3 attached, connecting remote offices using Frame-Relay Internetworking. 2 PVC's are mapped to the 2 7513's, one is primary the other is for backup. If I shut any of the connections the other end doesn't see it go away. I know this is because the frame is still seeing lmi responses and the ATM is still seeing OAM. How do I config to make the interfaces actually see the other end go down? No traffic will go to the backup PVC if the router thinks the primary is still up.
donewald
Level 6
Level 6
Check out FRF.8 Spec. End to end Frame to ATM pvc/vc management should get you what you want.
http://www.cisco.com/en/US/tech/tk39/tk53/technologies_configuration_example09186a00800945b3.shtml
Hope this helps you,
Don
Unfortunately, the switch belongs to AT&T, so I don't have any control over it. I am using 160X routers with point-to-point subinterfaces on the remote end and 7513's with PA-A3-T3's in VIPs also with point-to-point subinterfaces.
Here is the config of the serial interface on the remote:
interface Serial0
no ip address
encapsulation frame-relay
no ip route-cache
no ip mroute-cache
bandwidth 128
no fair-queue
service-module t1 timeslots 1-2
interface Serial0.60 point-to-point
description Primary PVC to AlnA ATM 11/0/0.905
ip address 192.168.7.66 255.255.255.252
no ip route-cache
no ip mroute-cache
bandwidth 128
frame-relay interface-dlci 60 IETF
interface Serial0.61 point-to-point
description Secondary PVC to AlnB ATM 11/0/0.905
ip address 192.168.7.70 255.255.255.252
no ip route-cache
no ip mroute-cache
bandwidth 4
frame-relay interface-dlci 61 IETF
interface Serial0.109 point-to-point
description Local DLCI 905
ip address 192.168.64.22 255.255.255.252
ip broadcast-address 192.168.64.23
no ip proxy-arp
no ip route-cache
no ip mroute-cache
frame-relay interface-dlci 109
Here is the config from one of the 7513's:
interface ATM11/0/0
no ip address
load-interval 30
atm uni-version 3.1
interface ATM11/0/0.51 point-to-point
description AlnB-SchRTR4 ATM 1/1/0.55
ip address 192.168.7.17 255.255.255.252
pvc SchRTR4 1/51
vbr-nrt 45000 45000 1
no ilmi manage
oam-pvc manage
interface ATM11/0/0.63 point-to-point
description AlnB-CMS2 ATM 6/0.61
ip address 192.168.7.13 255.255.255.252
pvc CMS1.63 1/63
no ilmi manage
oam-pvc manage
interface ATM11/0/0.65 point-to-point
description AlnB-SchRTR4 ATM 1/1/0.61
ip address 192.168.7.9 255.255.255.252
pvc SchRTR4.65 1/65
no ilmi manage
oam-pvc manage
interface ATM11/0/0.905 point-to-point
description Secondary ATM/FR Link to gwLoveland
bandwidth 4
ip address 192.168.7.69 255.255.255.252
pvc Loveland 1/905
protocol ip 192.168.7.71 broadcast
vbr-nrt 128 4 1
no ilmi manage
oam-pvc manage
encapsulation aal5snap
Any suggestions on what I can do with what is under my control?
For End to end PVC management you'll need some IWF/FRF.8 function in the cloud for this to happen. Possibly your provider can give you these functions. Here is another good link showing what is needed for this to occur.
http://www.cisco.com/warp/public/121/frf8_pvc_manage.html
Don
Don, Thanks. Scenario 2 in this document creates exactly what we are seeing. Now I just have to get AT&T to configure the IWF correctly.
