Basic routing question - I hope.
BRAD VAUGHN
I have a LAN that is running out of IP numbers. It is currently 192.168.1.x and I was going to add 192.168.5.x to the mix. I bought a 2621 and hooked FE0/0 to the existing network. I hung a switch off the FE0/1 and put a PC out there to test with the IP of 192.168.5.42. On the LAN I have a Number of Netware servers running IPX and a few NT servers running IP. IPX worked fine. IP is not playing nice however. From the router I can (standard)ping anything on either side. When I try to ping any hosts/servers on the 1.x side from the test PC or extended ping from the router's 5.2 interface, I get nothing. I have doen all kinds of NAT stuff in the past, but this is the first standard routing I've messed with. Any ideas why this won't work. Here is my current show run I have also tried router rip v2 to no avail and my static route I have tried setting the next hop for 1.x to FE0/0. The 0.0.0.0 route mentioned below is the firewall so that it sends unknown addresses out through the internet. Thanks for you help.
ip subnet-zero
interface FastEthernet0/0
ip address 192.168.1.39 255.255.255.0
duplex auto
speed auto
no cdp enable
interface FastEthernet0/1
ip address 192.168.5.2 255.255.255.0
duplex auto
speed auto
no cdp enable
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.1.27 permanent
ip route 192.168.5.0 255.255.255.0 FastEthernet0/0
no ip http server
ip pim bidir-enable
no cdp run
5 Replies 5
In your config, try to remove the following line
or it should be changed to
ip route 192.168.5.0 255.255.255.0 FastEthernet0/1
rjackson
Level 5
Level 5
sounds like you have added a second exit point from the 192.168.1.0 network. The servers probably have a gateway (default route) pointing to the firewall or nowhere if they were not using the firewall. They need to point to the .39 address so the router can route traffic destined for other ip networks.
To add to the last post,
all your client workstations and servers should point to their local router lan interface as the default gateway. On your 192.168.1.0 segment, if those servers/workstations have 192.168.1.27 as the default gateway, when they try to reply to a ping from 192.168.5.0, they will send the reply to 172.168.1.27 and the ping will fail.
you should not need a static route to the connected networks, since they are connected, the router knows how to get to them.
the default route should be the only static route you need to exit your two lan segments toward the internet or other networks.
hope this is helpful
psherwood
As on the previous replies, change your clients default GW to the router and remove the static ip route for the 192.168.5.0/24 network. If you don't want to change your gateway address of your client machines then you should add routes on the servers pointing to 192.168.1.39 for the 192.168.5.0/24 network, or better still, put a route on your FW (Gateway) pointing to 192.168.1.39 for the network 192.168.5.0
chris.burton
If you remove the ip route 192.168.5.0 255.255.255.0 FastEthernet0/0 it should work. Basically you are traying to route the traffic destined for 192.168.5.0/24 out of the interfaces that handles the 192.168.1.0/24 subnet.
Chris B.
