BGP problem
Ahmede
BGP was up and suddenley it went down and it doesn't want to come up again.. We removed all the BGP config and it just came down to the neighbor statments but still down.. We ran debug for TCP and BGP and here's the output..
112828: May 9 18:00:20.160: TCP0: Data repacketized, seq 2642756153, sent 56 byte
112829: May 9 18:00:26.024: TCB63A095A0 created
112830: May 9 18:00:26.024: TCP0: state was LISTEN -> SYNRCVD [179 -> 10.133.23
.17(15269)]
112831: May 9 18:00:26.024: TCP0: Connection to 10.133.23.17:15269, received MSS 1460, MSS is 516
112832: May 9 18:00:26.024: TCP: sending SYN, seq 2151872273, ack 2653104385
112833: May 9 18:00:26.024: TCP0: Connection to 10.133.23.17:15269, advertising MSS 1460
112834: May 9 18:00:26.024: TCP0: state was SYNRCVD -> ESTAB [179 -> 10.133.23.17(15269)]
112835: May 9 18:00:26.024: TCB6388CA58 callback, connection queue = 1
112836: May 9 18:00:26.024: TCB6388CA58 accepting 63A095A0 from 10.133.23.17.15269
112837: May 9 18:00:26.024: BGP: 10.133.23.17 passive open
112838: May 9 18:00:26.024: BGP: 10.133.23.17 went from Active to Idle
112839: May 9 18:00:26.024: BGP: 10.133.23.17 went from Idle to Connect
112840: May 9 18:00:26.028: TCP0: RST received, Closing connection
112841: May 9 18:00:26.028: TCP0: state was ESTAB -> CLOSED [179 -> 10.133.23.17(15269)]
112842: May 9 18:00:26.836: BGP: 10.133.23.17 remote close, state CLOSED
112843: May 9 18:00:26.836: BGP: 10.133.23.17 -reset the session
112844: May 9 18:00:27.836: BGP: 10.133.23.17 went from Connect to Idle
112845: May 9 18:00:27.836: BGP: 10.133.23.17 closing
112846: May 9 18:00:27.836: TCB 0x63A095A0 destroyed
112847: May 9 18:00:27.836: BGPNSF state: 10.133.23.17 went from nsf_not_active
to nsf_not_active
112848: May 9 18:00:48.833: BGP: 10.133.23.17 went from Idle to Active
112849: May 9 18:00:48.833: BGP: 10.133.23.17 open active, delay 18155ms
Any help please...
27 Replies 27
My first posting include debug ip bgp and debug ip tcp trans..
The most important part, which is when the session status gor from idle to connect is missing from the output you provided.
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222
Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
The initial posting includes the successful TCP handshake, the Idle->Connect msg, then immediately a reset from the far end.
I was referring to the BGP idle -> connect transition, just like you provided for the other router.
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
For whatever reason, the transport connection cannot get to Established. One side appears to get to Active, the other to OpenSent, but neither side can complete the process. The router ID in one of your posts above is showing up as 0.0.0.0, which is odd.
I think you see the remote router ID as 0.0.0.0 because BGP did not come up so the router can't detremine the remote router ID..
That's all we get from the debug.. It keeps on repeating.. Nothing more..
This doesn't jive with what we see in the "sh ip bgp nei 10.133.23.17", which show that 859 BGP open messages have been sent to the peer. We see none being received on the other side.
Something else is weird. The sh ip bgp nei shows:
External BGP neighbor may be up to 255 hops away
But ebgp-multihop is not configured on this neighbor.
I would recommend you move to the latest 12.3 mainline before proceeding with the troubleshooting of this issue.
Hope this helps,
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
I did upgarde my router to 12.3.13a and still not coming up.. Also I did remove all BGP config from my router and created new BGP with the wrong AS#, and I was waiting to get this message..
000199: May 11 14:54:12.736: %BGP-3-NOTIFICATION: received from neighbor 172.31.1.89 2/2 (peer in wrong AS) 2 bytes 0001
But I didn't.. I think we are not receiving any BGP updates...
what type of interface are the neighbor IP's addresses configured on?
Do you have any acl's on the transit interfaces?
The inetrfaces are FE and they are connected via switch,,, No access lists any where...
Please disregard this post if someone allready suggested the following,
I would get the following information to start with
conf t
no ip domain-lo
end
Router#sh tcp brief
TCB Local Address Foreign Address (state)
01A5C4F8 1.1.1.2.179 1.1.1.1.23905 ESTAB
sh tcp tcb 01A5C4F8
I think if you get the far end router to clear the tcp session session will be comeup.
e.g.
Router#clear tcp tcb 01A5C4F8
[confirm]
Hi all,
What may be the possible cause...kindly explains
