253
Enthusiast
BGP Regular Expressions
When I want to setup BGP regular expressions I read the command is
"IP AS-PATH ACCESS-LIST".
Is this the only command/verb syntax under BGP that will allow regular expressions?
2 REPLIES 2
Frequent Contributor
Re: BGP Regular Expressions
yes, as-path access-lists are the only place were regex can be used within BGP configuration.
Hope this helps you,
Don
Enthusiast
Thanks, I need to nail down some BGP items to build upon!!
Content for Community-Ad
July's Community Spotlight Awards
