Highlighted
Beginner
Broad cast control on LAN ????
I have to diffrent network in my LAN one whisch using private ip and the other is of real ip network.
I have two Vlan on C2950 from this i am connecting internet for these to 2 VLAN(2 network).
i have seen alot of broadcast on my Internet link ,,, genetrated bu these two VLAN...
how can i control there unwanted broadcast on C2950 ,,,, ,,, our LAN ver slow due to the Broadcast.... ,,,
thanks
1 REPLY 1
Enthusiast
Re: Broad cast control on LAN ????
You can use the storm-control feature on the C2950 to trace the source of the broacasts and optionally close the affected port(s).
If your LAN performance is affected by these broadcasts, I suggest you solve the problem at the source rather than on the switch.
Please refer to the following document:
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat2950/12122ea5/2950scg/swtrafc.htm#wp1063295
--Leon
* Please rate ALL posts.
