Highlighted
Beginner
Building EtherChannel between C6509 Switches using WS-X6548-GE-TX Ethernet card module
Dear support,
One more question relating to EtherChannel.
We have a 2x1gbps EtherChannel link built between an Access and Core switch in our Data center using two ports in a WS-X6548-GE-TX linecard module. However, I read in one Cisco document that only one port per module should be used in an EtherChannel because of the ASIC configuration in this type of module which limits the channel to 1gbps.
Please can you tell me whether this is still the case with C6509 running IOS 12.x. Otherwise, what is the recommended selection of ports for EtherChannel using the WS-X6548-GE-TX ethernet modules in 6509 switches.
Thank you very much.
Sankung
Everyone's tags (1)
Content for Community-Ad
July's Community Spotlight Awards
