03-29-2006 03:54 AM - edited 03-03-2019 02:32 AM
I've next message during boot-
System Bootstrap, Version 8.1(3)
Copyright (c) 1994-2004 by cisco Systems, Inc.
Cat6k-Sup720/SP processor with 524288 Kbytes of main memory
Autoboot executing command: "boot disk0:"
PCMCIA slot0 device is not initialized
open: read error...requested 0x4 bytes, got 0x0
trouble reading device magic number
boot: cannot open "disk0:"
boot: cannot determine first file name on device "disk0:"
Exit at the end of BOOT string
rommon 1 >
rommon 1 > dir disk0:
dir: cannot open device "disk0:"
How to resolve it?
Solved! Go to Solution.
03-29-2006 03:59 AM
You might have to try out the procedure in the following URL to get the box back:
http://www.cisco.com/warp/public/473/14.html
Hope that helps - pls rate the post if it does.
Paresh
03-29-2006 03:58 AM
hi
hope this helps..
http://www.cisco.com/en/US/products/hw/routers/ps133/products_field_notice09186a00800943d5.shtml
regds
03-29-2006 03:59 AM
Paresh
05-23-2020 06:54 AM
Broken link. Kindly update link please.
