Join Customer Connection to register!
134
knudsen-s
Beginner
Catalyst 2950-24, post security problem
Dear All,
I have instaled a 2950 switch and the customer whant to enable port security on 3 ports with a mac address.
The problem is when i write it comes with the error:
(config-if)#switchport port-security
Command rejected: Not eligible for secure port.
I have loaded det newest ios in it, but it has det error stil.
the ios is : c2950-i6q4l2-mz.121-9.EA1d.bin
any idee on this ?
Best regards
Soren Knudsen
CCIE
3 REPLIES 3
Prashanth Krishnappa
Try typing in "switchport mode access" and then type in the port security command. Also look at the following bug
http://www.cisco.com/cgi-bin/bugtool/onebug.pl?bugid=CSCdx33135
efrahim
Enthusiast
On the interface(s) you are trying to
turn port-security on first configure 'switchport mode access' - this will
stop the switchport from using DTP to try and negotiate a trunk - which
conflicts with the port-security command.
Thanx, it worked with sw mode acc
Best regards
Soren Knudsen
Content for Community-Ad
