12-09-2005 03:29 AM - edited 03-03-2019 01:04 AM
I have a 3500XL Catalyst switch and it has just stopped working.
The LED's on the front show up as:-
1,2,3,4 - no light
5,6 - Orange light
7-24 - Green light
System LED is flashing
RPS - no light
STAT, UTIL, DUPLEX, SPEED - Green light
All network activity has stopped, but if I keep the button on the front pressed and power the unit on I can log into the serial port.
IOS version is 12.0(5)WC13.
Does anyone know how I can fix this switch or has it taken a nose dive into the land of the dead?
Hope someone can help,
Best Regards
Scott
12-09-2005 03:52 AM
RPS is off coz u mite not have installed the same..
STAT, UTIL, DUPLEX, SPEED - Green light thats the normal signs..
But about the system is it normal green or orange ? is it flickering ?
do u have any pcs or devices connected in all the ports ???
Also refer this link for understanding the LED status also if possible and once ur in the console port do capture the error & logs and paste out here ...
regds
12-09-2005 04:39 AM
The Systems light is green and blinking, if this helps.
There are no devices plugged into any of the ports at the moment.
The model I have is the 3524XL.
This is the boot information I have:-
C3500XL Boot Loader (C3500-HBOOT-M) Version 12.0(5.3)WC(1), MAINTENANCE INTERIM SOFTWARE
Compiled Mon 30-Apr-01 07:51 by devgoyal
starting...
Base ethernet MAC Address: 00:07:eb:5a:9b:00
Xmodem file system is available.
Initializing Flash...
flashfs[0]: 167 files, 2 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 3612672
flashfs[0]: Bytes used: 3197952
flashfs[0]: Bytes available: 414720
flashfs[0]: flashfs fsck took 4 seconds.
...done Initializing Flash.
Boot Sector Filesystem (bs:) installed, fsid: 3
Parameter Block Filesystem (pb:) installed, fsid: 4
Loading "flash:c3500xl-c3h2s-mz.120-5.WC13.bin"...#################################################################################################################################################################################
File "flash:c3500xl-c3h2s-mz.120-5.WC13.bin" uncompressed and installed, entry point: 0x3000
executing...
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
IOS (tm) C3500XL Software (C3500XL-C3H2S-M), Version 12.0(5)WC13, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2005 by cisco Systems, Inc.
Compiled Tue 20-Sep-05 10:05 by antonino
Image text-base: 0x00003000, data-base: 0x00351FFC
Initializing C3500XL flash...
flashfs[1]: 167 files, 2 directories
flashfs[1]: 0 orphaned files, 0 orphaned directories
flashfs[1]: Total bytes: 3612672
flashfs[1]: Bytes used: 3197952
flashfs[1]: Bytes available: 414720
flashfs[1]: flashfs fsck took 4 seconds.
flashfs[1]: Initialization complete.
...done Initializing C3500XL flash.
C3500XL POST: System Board Test: Passed
C3500XL POST: Daughter Card Test: Passed
C3500XL POST: CPU Buffer Test: Passed
C3500XL POST FAILURE: CPU Notify RAM Test: Failed
C3500XL POST FAILURE: Error with CPU Interface CPU Notify RAM POST.
C3500XL POST FAILURE: CPU Interface Test: Failed
C3500XL POST FAILURE: Cannot test CPU Interface ASIC due to failure of
C3500XL POST FAILURE: CPU Interface CPU Notify RAM
C3500XL POST FAILURE: Testing Switch Core: Failed
C3500XL POST FAILURE: Testing Buffer Table: Failed
C3500XL POST FAILURE: Data Buffer Test: Failed
C3500XL POST FAILURE: Configuring Switch Parameters: Failed
C3500XL POST FAILURE: Switch Core failing because of CPU Interface Failure
C3500XL POST FAILURE: AT: Failing because of CPU-Interface failure
C3500XL POST FAILURE: Cannot test Modules due to failure of Switch Core POST
Does this help at all?
Best regards
Scott
12-09-2005 05:19 AM
Time for a new switch !!!!
12-09-2005 06:16 AM
Hi Scott,
You have to get the switch RMA from Cisco or get it replaced from whwrw you baught because it is failing the POST test which is power on self test.
So its a hardware failure and part need to be replaced.
Ankur
12-09-2005 06:47 AM
Oh well,
Thanks for everyone's replys and help, The cost of the repair will be too much for the company so it's for the bin.
Thanks again
Best regards
Scott
