I am imagining that you are not using the trunks on the Gig interfaces.
There are 2 ways to do this:
1, Make the Vlan interfaces and assign each interface in a different vlan and assign the proper IP's.
2, make the Ports as L3 ports by using command "no switchport" under the interface configurtaion and assign the proper IP addresses.
HTH,
-amit singh
