08-16-2002 11:55 AM - edited 03-02-2019 12:44 AM
I have Bootloader and MSFC Images on Catalyst 6506 switch. When the image corrupted. The MSFC will not bootup with bootloader automatically. I have both statements that point to both images in my configuration. When the image corrupted, the MSFC just keep like LOOPING, and will not be able to go to BootLoader image. Any suggestion?
08-16-2002 11:59 AM
Set up a bootldr variable using
6506-12a(config)#boot bootldr bootflash:
Also set the config-register to 0x2102
08-16-2002 12:06 PM
The following line already added.
Config-register already point to 0x2102
08-16-2002 12:17 PM
Sometimes it happens, even though the bootloader is there, but somehow the msfc still goes into loops, at that time like you have to break the loop,sending the break signal, and bring the MSFC into ROMMON, and boot the MSFC using the boot image and then delete the image ad even sometimes, you have to take out the bootflash SIM, to make it work again as mentioned in this document.
08-16-2002 01:11 PM
If you have the correct bootvariables, it should boot fine. Can you paste the outputs of dir bootflash:, sh bootvar and sh ver
08-16-2002 01:39 PM
I already verify all bootvar and bootflash:, Erum Frahim also posts same issue happening sometimes. This is not the first time it happens, and we have to send a tech out there to do "Missing MSFC recovery". We are still looking for the cause of this.
08-16-2002 01:44 PM
There is no "known" reason for the MSFC to behave this way if it has correct bootvariables and valid IOS files. If this is happening often, I suggest that you contact TAC
08-16-2002 06:43 PM
We simulate the issue by tftp a corrupted image and good bootloader, and have the bootvar point to the bootloader. It will go to a LOOP because of the corrupted image. Recently, we have TAC cases open and do some MSFC recovery. We want to find out the cause to avoid this happening, because we need to send out a tech everytime time happen. Thanks.
