Cisco Community Designated VIP Class of 2020
3262
Beginner
Cisco 2901 router Fan issue
Router Fan speed is too high but environment shows normal can any one guide
SYSTEM POWER SUPPLY STATUS
 Internal Power Supply  Type: AC
 Internal Power Supply  12V Output Status: Normal
 External Redundant Power Supply is absent or powered off
SYSTEM FAN STATUS
 Fan 1 OK, Low speed setting
 Fan 2 OK, Low speed setting
 Fan 3 OK, Low speed setting
 Fan 4 OK, Low speed setting
SYSTEM TEMPERATURE STATUS
 Intake Left temperature: 23 Celsius, Normal
 Intake Right temperature: 21 Celsius, Normal
 Exhaust Left temperature: 26 Celsius, Normal
 Exhaust Right temperature: 25 Celsius, Normal
 CPU temperature: 50 Celsius, Normal
 Power Supply Unit temperature: 43 Celsius, Normal
REAL TIME CLOCK BATTERY STATUS
 Battery OK (checked at power up)
SYSTEM POWER
 Motherboard Components Power consumption = 74.8 WPower consumption =
 ISM 0.0 WPower consumption =
 NM/SM slot 1 3.8 W
 Total System Power consumption is: 78.6 W
 Environmental information last updated 00:00:18 ago
SYSTEM FAN STATUS
 Fan 1 OK, fan level 1, Low speed setting, 11546 RPM, 40% PWM
 Fan 2 OK, fan level 1, Low speed setting, 5175 RPM, 40% PWM
 Fan 3 OK, fan level 1, Low speed setting, 5018 RPM, 40% PWM
 Fan 4 OK, fan level 1, Low speed setting, 5153 RPM, 40% PWM
 CPU temperature: 49 Celsius, Normal
SYSTEM ALARMS SETTINGS
 Fan tray removal or multi fan failure results in warning
 CPU Warning Over Temperature Alarm = 90C
 CPU Critical Over Temperature Alarm = 110C
 Intake Left Abnormal Temperature Alarm = 45C
 Intake Left Over Temperature Alarm = 57C
 Intake Right Abnormal Temperature Alarm = 45C
 Intake Right Over Temperature Alarm = 57C
 Exhaust Left Over Temperature Alarm = 75C
 Exhaust Right Over Temperature Alarm = 75C
 Power Supply Unit Over Temperature Alarm = 80C
 Power Supply Unit Over Critical Temperature Alarm = 95C
SYSTEM VOLTAGES
 12V voltage = 12.434 V, Normal
 5V voltage = 5.146 V, Normal
 3.3V voltage = 3.322 V, Normal
 2.5V voltage = 2.502 V, Normal
 1.8V voltage = 1.822 V, Normal
 1.2V voltage = 1.199 V, Normal
 ASIC voltage = 1.044 V, Normal
 CPU Core voltage = 1.213 V, Normal
SYSTEM POWER
 NM/SM slot 1 3.8 W
 Environmental information last updated 00:00:27 ago
ENVIRONMENTAL STRESS EVENTS
Critical Temperature: Maxium = 0
                      Total Duration = 0
 Exceed Fan Tray Removal Time: Maximum Time= 0
                               Total Time = 0
Total MCU access error count: 0
1 ACCEPTED SOLUTION
Highlighted
Re: Cisco 2901 router Fan issue
The RPM for Fan 1 is high but it does not seem to be an issue from the looks of it -
Are both the ISR running the same IOS ? Do you see any buffered warning messages if you do "show logg" ?
Nipun Singh Raghav
"We cannot solve our problems with the same thinking we used when we created them"
4 REPLIES 4
How do you know that it is too high ?
Nipun Singh Raghav
Beginner
By comparing noise of 2 2901 router on the same rack..slightly high fan speed
Highlighted
Nipun Singh Raghav
Beginner
Hi Nipun,
I doesn't see any buffered msgs in logs, See in attached snap. Also PTCL router are running on 15.2 IOS while cybernet router is on 15.5.
Content for Community-Ad
FusionCharts will render here
