03-22-2002 07:37 AM - edited 03-01-2019 08:59 PM
I have been asked to configure two Cisco 3620s to talk to each other over a megastream line. As I have mainly worked with Gigabit Ethernet, I thought a good starting point would be Config Maker. I added the two routers, both with the same PRI Network modules but I was unable to add an ISDN line between them. Config Maker stated that one must be PRI and the other BRI. Am I being asked to do the impossible?
03-22-2002 09:27 PM
Thats not true at all. PRI side can connect to another PRI. That must be a configmake bug. Dont use that. Just configure from CLI.
03-27-2002 04:00 AM
Thanks for that! Can you point me to any examples, as I have never config'd PRI. I just want to utilise the full bandwidth, point-to-point, between the two routers.
