My existing 4006 chassis is using Supervisor III (WS-X4014).
I have another 4506 chassis using Supervisor IV (WS-X4515) and a Netflow Services Card (WS-F4531) build on top of it.
I need Netflow Services Card in 4006, so can I just replace the Supervisor IV (WS-X4515) used in cisco 4006? Is it compatible with 4006?
Any suggestion?
HowYee
hi HowYee,
according to that document, it is not possible if you want to put supIV to 4006 chassis
Chassis and Line-Card Support
You can deploy the supervisor engine IV in single-chassis nonredundant mode in the Cisco Catalyst 4503, 4503-E, 4506, and 4506-E chassis. You can also deploy it in single-chassis redundant mode as an option in the Cisco Catalyst 4507R chassis (slots 1 and 2 only) and Cisco Catalyst 4507R-E/4507R+E chassis (slots 3 and 4).
The supervisor engine IV is compatible with the classic Cisco Catalyst 4500 and the E-series Cisco Catalyst 4500 Line Cards. Table 1 gives performance information for the Cisco Catalyst 4500 Series Supervisor Engine IV.
regards,
