Cisco 4006 & 4506 sup engine
HowYee
My existing 4006 chassis is using Supervisor III (WS-X4014).
I have another 4506 chassis using Supervisor IV (WS-X4515) and a Netflow Services Card (WS-F4531) build on top of it.
I need Netflow Services Card in 4006, so can I just replace the Supervisor IV (WS-X4515) used in cisco 4006? Is it compatible with 4006?
Any suggestion?
HowYee
handoko wiyanto
Level 3
Level 3
hi HowYee,
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps4324/product_data_sheet0900aecd8035cf2b.html
according to that document, it is not possible if you want to put supIV to 4006 chassis
Chassis and Line-Card Support
You  can deploy the supervisor engine IV in single-chassis nonredundant mode  in the Cisco Catalyst 4503, 4503-E, 4506, and 4506-E chassis. You can  also deploy it in single-chassis redundant mode as an option in the  Cisco Catalyst 4507R chassis (slots 1 and 2 only) and Cisco Catalyst  4507R-E/4507R+E chassis (slots 3 and 4).
The  supervisor engine IV is compatible with the classic Cisco Catalyst 4500  and the E-series Cisco Catalyst 4500 Line Cards. Table 1 gives  performance information for the Cisco Catalyst 4500 Series Supervisor  Engine IV.
regards,
