09-23-2020 03:06 AM
Hello Members,
I have 881 router and it has 1 WAN port and 4 Fa ports. My ISP has configured WAN port sub interfaces for both Internet and MPLS. My challenge is I want Internet connection to got through the Firewall before going to the switch. MPLS should directly connect to the switch from the router. How should I connect considering all all other ports are ethernet ports? Below are configs
interface GigabitEthernet0/0/0
no ip address
ip nat outside
negotiation auto
interface GigabitEthernet0/0/0.1134
description test INTERNET
encapsulation dot1Q 1134
ip address 41.90.230.218 255.255.255.252
ip nat outside
interface GigabitEthernet0/0/0.2090
description test MPLS
encapsulation dot1Q 2090
ip address 172.90.140.119 255.255.255.252
ip nat inside
interface GigabitEthernet0/0/1
ip address 172.19.4.5 255.255.255.0
ip nat inside
negotiation auto
interface Service-Engine0/1/0
vrf forwarding Mgmt-intf
no ip address
negotiation auto
09-23-2020 10:14 AM
The text says that you have a WAN port and 4 fa. But the partial config that you post has G0/0/0, G0/0/1, and G0. How can we reconcile these differences?
Your description indicates that in addition to the router there is an ISP, a switch, and a firewall. Can you explain how these are connected? It appears that ISP connects to G0/0/0. But what about the switch and what about the firewall?
09-23-2020 10:35 PM
My connections are as below.
FEWAN - isp
FELAN1 - SWICTH
felan2-Firewall
