724
axelhauguel
Beginner
Cisco N9K ARP issue / Proxmox Issue
I write you because i'have a problem with a customer.
Here my configuration :
interface Vlan50
  no shutdown
  ip access-group customers in
  ip access-group 50-anti-ddos-in out
  no ip redirects
  ip address 193.38.250.1/24
  ip address 45.154.96.1/24 secondary
  ip address 185.171.202.1/24 secondary
  ipv6 address 2a10:4640:1::1/48
  ipv6 address 2a10:4640:3::1/48
  ipv6 address 2a10:4640::1/48
  ip arp timeout 60
When I create a container with "185.171.202.X" IP, it's work immediately.
But when I create a container with IP "45.154.96.X/24", it does not work until I do a ping into the container, to external IP.
Seem ARP issue.
No issue with a VM with Windows.
Do you have an idea ?
Axel
6 REPLIES 6
pman
Beginner
please attache:
  show ip route
  show ip arp
  network topology/diagram include physical interfaces names
  show access-list
Thanks.
edge01.par9k#   show ip route
IP Route Table for VRF "default"
'*' denotes best ucast next-hop
'**' denotes best mcast next-hop
'[x/y]' denotes [preference/metric]
'%<string>' in via output denotes VRF <string>
0.0.0.0/0, ubest/mbest: 1/0
    *via 100.64.70.5, [1/0], 4d14h, static
1.0.0.0/24, ubest/mbest: 1/0
    *via 100.64.70.5, [20/0], 2d13h, bgp-212815, external, tag 49434
1.0.4.0/22, ubest/mbest: 1/0
    *via 100.64.70.5, [20/0], 5d14h, bgp-212815, external, tag 49434
1.0.4.0/24, ubest/mbest: 1/0
1.0.5.0/24, ubest/mbest: 1/0
    *via 100.64.70.5, [20/0], 5d18h, bgp-212815, external, tag 49434
1.0.6.0/24, ubest/mbest: 1/0
1.0.7.0/24, ubest/mbest: 1/0
1.0.64.0/18, ubest/mbest: 1/0
    *via 100.64.70.5, [20/0], 2d09h, bgp-212815, external, tag 49434
1.0.128.0/17, ubest/mbest: 1/0
    *via 37.49.237.123, [20/0], 1w6d, bgp-212815, external, tag 38040
1.0.128.0/18, ubest/mbest: 1/0
1.0.128.0/19, ubest/mbest: 1/0
1.0.128.0/24, ubest/mbest: 1/0
1.0.129.0/24, ubest/mbest: 1/0
1.0.130.0/23, ubest/mbest: 1/0
1.0.132.0/24, ubest/mbest: 1/0
1.0.133.0/24, ubest/mbest: 1/0
1.0.136.0/24, ubest/mbest: 1/0
1.0.137.0/24, ubest/mbest: 1/0
    *via 37.49.237.123, [20/0], 2d02h, bgp-212815, external, tag 38040
1.0.138.0/24, ubest/mbest: 1/0
1.0.139.0/24, ubest/mbest: 1/0
% cli: command canceled
edge01.par9k#   show ip route sum
Total number of routes: 839536
Total number of paths:  839539
Unicast paths:
Best paths per protocol:      Backup paths per protocol:
  am             : 758          static         : 3
  local          : 6
  direct         : 6
  static         : 1
  broadcast      : 15
  bgp-212815     : 838750
Number of routes per mask-length:
  /0 : 1       /8 : 17      /9 : 13      /10: 40      /11: 100
  /12: 301     /13: 587     /14: 1183    /15: 2036    /16: 13397
  /17: 8129    /18: 13673   /19: 24726   /20: 39950   /21: 48803
  /22: 104704  /23: 89534   /24: 491530  /28: 2       /30: 3
  /32: 807
edge01.par9k#
edge01.par9k#   show ip arp
Flags: * - Adjacencies learnt on non-active FHRP router
       + - Adjacencies synced via CFSoE
       # - Adjacencies Throttled for Glean
       CP - Added via L2RIB, Control plane Adjacencies
       PS - Added via L2RIB, Peer Sync
       RO - Re-Originated Peer Sync Entry
       D - Static Adjacencies attached to down interface
IP ARP Table for context default
Total number of entries: 767
Address         Age       MAC Address     Interface       Flags
45.154.96.2     00:00:38  3683.507f.e593  Vlan50
45.154.96.200   00:00:29  8e96.313d.3b06  Vlan50
45.154.96.253   00:00:37  ba47.fef9.4afb  Vlan50
185.171.202.2   00:00:19  c80a.a932.b7e4  Vlan50
185.171.202.3   00:00:26  8e73.999e.c172  Vlan50
185.171.202.4   00:00:38  c80a.a932.b826  Vlan50
185.171.202.5   00:00:38  c80a.a91f.a00e  Vlan50
185.171.202.6   00:00:38  c80a.a932.b828  Vlan50
185.171.202.9   00:00:37  5c26.0afc.4d50  Vlan50
185.171.202.10  00:00:37  5c26.0afc.4d50  Vlan50
185.171.202.11  0.875134  INCOMPLETE      Vlan50
185.171.202.12  00:00:37  1803.730c.bba5  Vlan50
185.171.202.13  00:00:38  c80a.a91f.a00e  Vlan50
185.171.202.14  00:00:37  5c26.0afc.4d50  Vlan50
185.171.202.15  00:00:37  5c26.0afc.4d50  Vlan50
185.171.202.16  00:00:37  c80a.a932.b828  Vlan50
185.171.202.17  00:00:37  c80a.a932.b828  Vlan50
185.171.202.18  00:00:38  c80a.a932.b826  Vlan50
185.171.202.19  00:00:38  c80a.a91f.a00e  Vlan50
185.171.202.20  00:00:37  c80a.a932.b828  Vlan50
185.171.202.21  00:00:38  c80a.a932.b826  Vlan50
185.171.202.22  00:00:09  1e68.3638.3151  Vlan50
185.171.202.23  00:00:38  5c26.0afc.4d50  Vlan50
185.171.202.24  00:00:38  c80a.a932.b826  Vlan50
185.171.202.25  00:00:38  c80a.a932.b828  Vlan50
185.171.202.26  00:00:36  0016.3c16.0e18  Vlan50
185.171.202.28  00:00:37  c80a.a932.b826  Vlan50
185.171.202.29  00:00:38  c80a.a91f.a00e  Vlan50
185.171.202.30  00:00:38  c80a.a932.b826  Vlan50
185.171.202.31  00:00:39  0016.3c2d.2ae7  Vlan50
185.171.202.32  00:00:37  5c26.0afc.4d50  Vlan50
185.171.202.34  00:00:37  5c26.0afc.4d50  Vlan50
185.171.202.35  00:00:11  0016.3cb7.cd4e  Vlan50
185.171.202.36  00:00:37  c80a.a932.b828  Vlan50
185.171.202.38  00:00:37  5c26.0afc.4d50  Vlan50
185.171.202.39  00:00:37  c80a.a932.b828  Vlan50
185.171.202.41  00:00:38  c80a.a932.b826  Vlan50
185.171.202.42  00:00:37  5c26.0afc.4d50  Vlan50
185.171.202.43  00:00:01  INCOMPLETE      Vlan50
185.171.202.44  00:00:38  c80a.a932.b826  Vlan50
185.171.202.45  00:00:37  c80a.a932.b828  Vlan50
185.171.202.47  00:00:16  0016.3c1b.57ca  Vlan50
185.171.202.48  00:00:01  INCOMPLETE      Vlan50
185.171.202.49  00:00:38  c80a.a91f.a00e  Vlan50
185.171.202.50  00:00:38  c80a.a932.b826  Vlan50
185.171.202.52  00:00:38  c80a.a932.b826  Vlan50
185.171.202.53  00:00:38  c80a.a91f.a00e  Vlan50
185.171.202.54  00:00:37  c80a.a932.b828  Vlan50
185.171.202.56  00:00:38  c80a.a932.b826  Vlan50
185.171.202.57  00:00:37  c80a.a932.b828  Vlan50
185.171.202.58  00:00:04  c80a.a932.b826  Vlan50
185.171.202.61  00:00:37  5c26.0afc.4d50  Vlan50
185.171.202.62  00:00:37  fe97.179b.e111  Vlan50
185.171.202.63  00:00:38  c80a.a932.b826  Vlan50
185.171.202.64  00:00:38  c80a.a932.b828  Vlan50
185.171.202.67  00:00:37  5c26.0afc.4d50  Vlan50
185.171.202.69  00:00:37  5c26.0afc.4d50  Vlan50
185.171.202.70  00:00:37  5c26.0afc.4d50  Vlan50
185.171.202.73  00:00:37  6a29.a830.1e7a  Vlan50
185.171.202.74  00:00:01  INCOMPLETE      Vlan50
185.171.202.75  00:00:37  5c26.0afc.4d50  Vlan50
185.171.202.76  00:00:37  5c26.0afc.4d50  Vlan50
185.171.202.77  00:00:23  aa21.5a73.916f  Vlan50
185.171.202.78  00:00:38  663a.31be.5f8a  Vlan50
185.171.202.79  00:00:38  4ae4.cd74.0e5e  Vlan50
185.171.202.80  00:00:39  767a.c343.b7e3  Vlan50
185.171.202.81  00:00:37  e224.38de.469d  Vlan50
185.171.202.83  00:00:39  0855.31e1.7eb7  Vlan50
185.171.202.84  00:00:02  68d7.9a66.4cd0  Vlan50
185.171.202.88  00:00:38  c80a.a932.b826  Vlan50
185.171.202.91  00:00:01  INCOMPLETE      Vlan50
185.171.202.92  00:00:26  5c26.0afd.15c0  Vlan50
185.171.202.94  00:00:12  0016.3ce1.5eae  Vlan50
185.171.202.95  00:00:37  5c26.0afc.4d50  Vlan50
185.171.202.96  00:00:37  5c26.0afc.4d50  Vlan50
185.171.202.98  00:00:37  5c26.0afc.4d50  Vlan50
185.171.202.100 00:00:38  c80a.a932.b828  Vlan50
185.171.202.101 00:00:37  c80a.a932.b828  Vlan50
185.171.202.102 00:00:39  0016.3c4c.9e39  Vlan50
185.171.202.105 00:00:38  c80a.a932.b826  Vlan50
185.171.202.106 00:00:37  c80a.a932.b828  Vlan50
185.171.202.107 00:00:38  c80a.a932.b828  Vlan50
185.171.202.108 00:00:37  c80a.a932.b828  Vlan50
185.171.202.109 00:00:38  c80a.a91f.a00e  Vlan50
185.171.202.110 00:00:38  c80a.a91f.a00e  Vlan50
185.171.202.111 00:00:37  c80a.a932.b828  Vlan50
185.171.202.112 00:00:02  INCOMPLETE      Vlan50
185.171.202.113 00:00:37  5c26.0afc.4d50  Vlan50
185.171.202.114 00:00:38  c80a.a932.b826  Vlan50
185.171.202.115 00:00:38  c80a.a932.b826  Vlan50
185.171.202.116 00:00:37  c80a.a932.b828  Vlan50
185.171.202.118 00:00:37  c80a.a932.b828  Vlan50
185.171.202.119 00:00:38  c80a.a91f.a00e  Vlan50
185.171.202.120 00:00:38  c80a.a932.b826  Vlan50
185.171.202.121 00:00:37  c80a.a932.b7e4  Vlan50
185.171.202.122 00:00:38  1a49.804f.4641  Vlan50
185.171.202.123 00:00:38  c80a.a932.b826  Vlan50
185.171.202.124 00:00:34  0016.3c9b.ebdc  Vlan50
185.171.202.125 00:00:10  0016.3c9f.218f  Vlan50
185.171.202.126 00:00:41  c80a.a932.b7f4  Vlan50
185.171.202.127 00:00:37  5c26.0afc.4d50  Vlan50
185.171.202.128 00:00:38  c80a.a932.b828  Vlan50
185.171.202.129 00:00:37  c80a.a932.b828  Vlan50
185.171.202.130 00:00:41  0016.3c26.d0e1  Vlan50
185.171.202.131 00:00:37  5c26.0afc.4d50  Vlan50
185.171.202.132 00:00:09  0016.3c4f.9b9b  Vlan50
185.171.202.133 00:00:38  0016.3cf7.e756  Vlan50
185.171.202.134 00:00:37  ce89.7ab0.c021  Vlan50
185.171.202.135 00:00:38  c80a.a932.b826  Vlan50
185.171.202.136 00:00:38  c80a.a932.b828  Vlan50
185.171.202.138 00:00:37  c80a.a932.b828  Vlan50
185.171.202.140 00:00:38  c80a.a91f.a00e  Vlan50
185.171.202.141 00:00:38  c80a.a932.b826  Vlan50
185.171.202.142 00:00:37  c80a.a932.b828  Vlan50
185.171.202.143 00:00:37  c80a.a932.b828  Vlan50
185.171.202.144 00:00:38  c80a.a932.b828  Vlan50
185.171.202.145 00:00:38  c80a.a91f.a00e  Vlan50
185.171.202.147 00:00:38  c80a.a932.b826  Vlan50
185.171.202.148 00:00:33  0016.3c5f.5473  Vlan50
185.171.202.149 00:00:38  c80a.a932.b828  Vlan50
185.171.202.150 00:00:38  c80a.a932.b826  Vlan50
185.171.202.151 00:00:38  c80a.a932.b828  Vlan50
185.171.202.152 00:00:37  5c26.0afc.4d50  Vlan50
185.171.202.153 00:00:37  c80a.a91f.a00e  Vlan50
185.171.202.154 00:00:37  5c26.0afc.4d50  Vlan50
185.171.202.155 00:00:37  5c26.0afc.4d50  Vlan50
185.171.202.156 00:00:37  c80a.a932.b828  Vlan50
185.171.202.157 00:00:38  c80a.a91f.a00e  Vlan50
185.171.202.158 00:00:38  c80a.a932.b826  Vlan50
185.171.202.159 00:00:37  5c26.0afc.4d50  Vlan50
185.171.202.160 00:00:37  5c26.0afc.4d50  Vlan50
185.171.202.161 00:00:38  c80a.a932.b826  Vlan50
185.171.202.162 00:00:38  c80a.a91f.a00e  Vlan50
185.171.202.163 00:00:38  c80a.a91f.a00e  Vlan50
185.171.202.164 00:00:38  c80a.a91f.a00e  Vlan50
185.171.202.165 00:00:38  c80a.a91f.a00e  Vlan50
185.171.202.166 00:00:37  5c26.0afc.4d50  Vlan50
185.171.202.167 00:00:38  c80a.a932.b828  Vlan50
185.171.202.168 00:00:38  c80a.a91f.a00e  Vlan50
185.171.202.169 00:00:38  c80a.a91f.a00e  Vlan50
185.171.202.170 00:00:38  c80a.a932.b826  Vlan50
185.171.202.171 00:00:37  c80a.a932.b828  Vlan50
185.171.202.172 00:00:37  5c26.0afc.4d50  Vlan50
185.171.202.173 00:00:37  c80a.a932.b828  Vlan50
185.171.202.174 00:00:38  c80a.a91f.a00e  Vlan50
185.171.202.175 00:00:38  c80a.a91f.a00e  Vlan50
185.171.202.176 00:00:30  0016.3cc6.7ad3  Vlan50
185.171.202.177 00:00:37  c80a.a932.b828  Vlan50
185.171.202.178 00:00:39  0016.3c45.8130  Vlan50
185.171.202.180 00:00:38  c80a.a932.b826  Vlan50
185.171.202.181 00:00:38  c80a.a91f.a00e  Vlan50
185.171.202.182 00:00:38  c80a.a91f.a00e  Vlan50
185.171.202.184 00:00:37  5c26.0afc.4d50  Vlan50
185.171.202.185 00:00:39  0016.3c80.bc70  Vlan50
185.171.202.186 00:00:37  c80a.a932.b828  Vlan50
185.171.202.187 00:00:38  c80a.a91f.a00e  Vlan50
185.171.202.188 00:00:38  c80a.a91f.a00e  Vlan50
185.171.202.189 00:00:38  c80a.a932.b828  Vlan50
185.171.202.190 00:00:38  c80a.a932.b828  Vlan50
185.171.202.192 00:00:37  5c26.0afc.4d50  Vlan50
185.171.202.193 0.616439  INCOMPLETE      Vlan50
185.171.202.194 00:00:37  5c26.0afc.4d50  Vlan50
185.171.202.195 00:00:38  c80a.a932.b826  Vlan50
185.171.202.196 00:00:37  c80a.a932.b828  Vlan50
185.171.202.197 00:00:39  1eb1.f02d.b7e9  Vlan50
185.171.202.198 00:00:37  4eb6.6420.ac68  Vlan50
185.171.202.199 00:00:24  c20f.759b.2d2a  Vlan50
185.171.202.200 00:00:30  0016.3c37.7803  Vlan50
185.171.202.201 00:00:38  5c26.0afc.4d50  Vlan50
185.171.202.203 00:00:37  5c26.0afc.4d50  Vlan50
185.171.202.204 00:00:36  1639.3352.81cf  Vlan50
185.171.202.205 00:00:31  d6f8.9a69.73ed  Vlan50
185.171.202.206 00:00:38  c80a.a91f.a00e  Vlan50
185.171.202.207 00:00:38  c80a.a91f.a00e  Vlan50
185.171.202.210 00:00:37  5c26.0afc.4d50  Vlan50
185.171.202.213 00:00:05  82eb.5786.8661  Vlan50
185.171.202.214 00:00:09  8244.1bfb.e07d  Vlan50
185.171.202.215 00:00:25  42af.6a4f.d287  Vlan50
185.171.202.216 00:00:14  5eb6.dc74.8cf8  Vlan50
185.171.202.221 00:00:22  8e35.ea09.8752  Vlan50
185.171.202.227 0.130392  INCOMPLETE      Vlan50
185.171.202.229 00:00:02  INCOMPLETE      Vlan50
185.171.202.230 00:00:37  b6c7.80b7.0149  Vlan50
185.171.202.231 00:00:14  782b.cb46.e658  Vlan50
185.171.202.232 00:00:22  c665.3973.6784  Vlan50
185.171.202.233 00:00:35  1a8b.e5a1.8d12  Vlan50
185.171.202.234 0.856981  INCOMPLETE      Vlan50
185.171.202.235 00:00:10  de26.08ec.9f6e  Vlan50
185.171.202.237 00:00:39  eabe.b519.94bf  Vlan50
185.171.202.238 00:00:38  1219.6f97.f526  Vlan50
185.171.202.239 00:00:37  d2de.84ea.1329  Vlan50
185.171.202.240 00:00:04  ba74.9ad9.766e  Vlan50
185.171.202.241 00:00:07  8e92.3f54.7241  Vlan50
185.171.202.242 00:00:40  06fb.412d.e4d4  Vlan50
185.171.202.243 00:00:02  8e76.dbc9.0965  Vlan50
185.171.202.244 00:00:37  caff.287f.a5ce  Vlan50
185.171.202.246 00:00:38  0855.3126.939d  Vlan50
185.171.202.247 00:00:38  1211.0746.0b09  Vlan50
185.171.202.248 00:00:33  2a5b.ce84.2b25  Vlan50
185.171.202.249 00:00:37  5c26.0afc.4d50  Vlan50
185.171.202.250 00:00:14  c80a.a932.c01a  Vlan50
185.171.202.251 00:00:15  3ee6.9a16.7bd3  Vlan50
185.171.202.252 00:00:37  8e5c.3c5c.e858  Vlan50
185.171.202.253 00:00:01  c80a.a932.b949  Vlan50
193.38.250.3    00:00:37  2ab2.6f45.a77c  Vlan50
193.38.250.4    00:00:37  2ab2.6f45.a77c  Vlan50
193.38.250.5    00:00:37  2ab2.6f45.a77c  Vlan50
193.38.250.6    00:00:37  2ab2.6f45.a77c  Vlan50
193.38.250.7    00:00:37  2ab2.6f45.a77c  Vlan50
193.38.250.8    00:00:37  2ab2.6f45.a77c  Vlan50
193.38.250.9    00:00:37  2ab2.6f45.a77c  Vlan50
193.38.250.10   00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.11   00:00:37  2ab2.6f45.a77c  Vlan50
193.38.250.12   00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.13   00:00:37  2ab2.6f45.a77c  Vlan50
193.38.250.14   00:00:37  2ab2.6f45.a77c  Vlan50
193.38.250.15   00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.16   00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.17   00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.18   00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.19   00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.20   00:00:37  2ab2.6f45.a77c  Vlan50
193.38.250.21   00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.22   00:00:37  2ab2.6f45.a77c  Vlan50
193.38.250.23   00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.24   00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.25   00:00:37  2ab2.6f45.a77c  Vlan50
193.38.250.26   00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.27   00:00:37  2ab2.6f45.a77c  Vlan50
193.38.250.28   00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.29   00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.30   00:00:37  2ab2.6f45.a77c  Vlan50
193.38.250.31   00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.32   00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.33   00:00:37  2ab2.6f45.a77c  Vlan50
193.38.250.34   00:00:37  2ab2.6f45.a77c  Vlan50
193.38.250.35   00:00:37  2ab2.6f45.a77c  Vlan50
193.38.250.36   00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.37   00:00:37  2ab2.6f45.a77c  Vlan50
193.38.250.38   00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.39   00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.40   00:00:37  2ab2.6f45.a77c  Vlan50
193.38.250.41   00:00:37  2ab2.6f45.a77c  Vlan50
193.38.250.42   00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.43   00:00:37  2ab2.6f45.a77c  Vlan50
193.38.250.44   00:00:37  2ab2.6f45.a77c  Vlan50
193.38.250.45   00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.46   00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.47   00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.48   00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.49   00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.50   00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.51   00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.52   00:00:37  2ab2.6f45.a77c  Vlan50
193.38.250.53   00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.54   00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.55   00:00:37  2ab2.6f45.a77c  Vlan50
193.38.250.56   00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.57   00:00:37  2ab2.6f45.a77c  Vlan50
193.38.250.58   00:00:37  2ab2.6f45.a77c  Vlan50
193.38.250.59   00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.60   00:00:37  2ab2.6f45.a77c  Vlan50
193.38.250.61   00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.62   00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.63   00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.64   00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.65   00:00:37  2ab2.6f45.a77c  Vlan50
193.38.250.66   00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.67   00:00:37  2ab2.6f45.a77c  Vlan50
193.38.250.68   00:00:37  2ab2.6f45.a77c  Vlan50
193.38.250.69   00:00:37  2ab2.6f45.a77c  Vlan50
193.38.250.70   00:00:37  2ab2.6f45.a77c  Vlan50
193.38.250.71   00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.72   00:00:37  2ab2.6f45.a77c  Vlan50
193.38.250.73   00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.74   00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.75   00:00:37  2ab2.6f45.a77c  Vlan50
193.38.250.76   00:00:37  2ab2.6f45.a77c  Vlan50
193.38.250.77   00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.78   00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.79   00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.80   00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.81   00:00:37  2ab2.6f45.a77c  Vlan50
193.38.250.82   00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.83   00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.84   00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.85   00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.86   00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.87   00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.88   00:00:37  2ab2.6f45.a77c  Vlan50
193.38.250.89   00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.90   00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.91   00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.92   00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.93   00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.94   00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.95   00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.96   00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.97   00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.98   00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.99   00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.100  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.101  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.102  00:00:37  2ab2.6f45.a77c  Vlan50
193.38.250.103  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.104  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.105  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.106  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.107  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.108  00:00:37  2ab2.6f45.a77c  Vlan50
193.38.250.109  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.110  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.111  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.112  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.113  00:00:37  2ab2.6f45.a77c  Vlan50
193.38.250.114  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.115  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.116  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.117  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.118  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.119  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.120  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.121  00:00:37  2ab2.6f45.a77c  Vlan50
193.38.250.122  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.123  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.124  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.125  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.126  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.127  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.128  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.129  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.130  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.131  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.132  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.133  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.134  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.135  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.136  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.137  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.138  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.139  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.140  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.141  00:00:37  2ab2.6f45.a77c  Vlan50
193.38.250.142  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.143  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.144  00:00:37  2ab2.6f45.a77c  Vlan50
193.38.250.145  00:00:37  2ab2.6f45.a77c  Vlan50
193.38.250.146  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.147  00:00:37  2ab2.6f45.a77c  Vlan50
193.38.250.148  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.149  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.150  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.151  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.152  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.153  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.154  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.155  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.156  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.157  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.158  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.159  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.160  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.161  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.162  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.163  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.164  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.165  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.166  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.167  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.168  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.169  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.170  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.171  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.172  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.173  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.174  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.175  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.176  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.177  00:00:37  2ab2.6f45.a77c  Vlan50
193.38.250.178  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.179  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.180  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.181  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.182  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.183  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.184  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.185  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.186  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.187  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.188  00:00:37  2ab2.6f45.a77c  Vlan50
193.38.250.189  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.190  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.191  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.192  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.193  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.194  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.195  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.196  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.197  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.198  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.199  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.200  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.201  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.202  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.203  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.204  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.205  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.206  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.207  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.208  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.209  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.210  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.211  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.212  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.213  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.214  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.215  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.216  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.217  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.218  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.219  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.220  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.221  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.222  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.223  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.224  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.225  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.226  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.227  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.228  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.229  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.230  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.231  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.232  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.233  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.234  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.235  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.236  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.237  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.238  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.239  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.240  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.241  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.242  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.243  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.244  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.245  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.246  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.247  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.248  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.249  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.250  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.251  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.252  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.253  00:00:38  2ab2.6f45.a77c  Vlan50
193.38.250.254  00:00:38  2ab2.6f45.a77c  Vlan50
37.49.236.1     00:14:20  2242.1f4a.9fcd  Ethernet1/54.403
37.49.236.2     00:08:44  001d.b5c4.c7c7  Ethernet1/54.403
37.49.236.4     00:02:26  748e.f8a9.7401  Ethernet1/54.403
37.49.236.8     00:09:58  4c00.82b3.3690  Ethernet1/54.403
37.49.236.10    00:09:21  0024.387e.7100  Ethernet1/54.403
37.49.236.11    00:09:58  6412.25e9.bfc0  Ethernet1/54.403
37.49.236.12    00:09:54  a80c.0d45.6c49  Ethernet1/54.403
37.49.236.13    00:13:13  b8c2.5334.c05c  Ethernet1/54.403
37.49.236.14    00:09:54  8478.ac54.868e  Ethernet1/54.403
37.49.236.16    00:04:30  cc4e.2493.2d00  Ethernet1/54.403
37.49.236.19    00:11:22  2aa2.4b74.79b3  Ethernet1/54.403
37.49.236.22    00:02:32  748e.f8a3.8ab3  Ethernet1/54.403
37.49.236.23    00:05:13  88cf.9861.7396  Ethernet1/54.403
37.49.236.24    00:09:29  008a.96f7.3ca0  Ethernet1/54.403
37.49.236.26    00:04:38  182a.d36d.2812  Ethernet1/54.403
37.49.236.28    00:08:14  cc1a.fae9.1d20  Ethernet1/54.403
37.49.236.29    00:12:45  88e6.4bce.5c17  Ethernet1/54.403
37.49.236.30    00:01:13  985d.82b7.a14f  Ethernet1/54.403
37.49.236.31    00:01:59  001c.0f5e.ba00  Ethernet1/54.403
37.49.236.32    00:09:23  0476.b098.ecad  Ethernet1/54.403
37.49.236.33    00:01:46  748e.f863.c94f  Ethernet1/54.403
37.49.236.35    00:09:30  a8d0.e5d8.e5d2  Ethernet1/54.403
37.49.236.36    00:03:53  008a.9684.f030  Ethernet1/54.403
37.49.236.38    00:01:35  609c.9f83.a381  Ethernet1/54.403
37.49.236.39    00:02:14  985d.8271.cbb5  Ethernet1/54.403
37.49.236.40    00:10:26  3c61.04cc.33df  Ethernet1/54.403
37.49.236.42    00:15:54  44f4.778c.1ac1  Ethernet1/54.403
37.49.236.44    00:06:30  40de.addc.e08a  Ethernet1/54.403
37.49.236.45    00:03:43  0478.6600.c200  Ethernet1/54.403
37.49.236.47    00:01:11  6c6c.d337.23d6  Ethernet1/54.403
37.49.236.48    00:00:08  90e2.ba8c.79b0  Ethernet1/54.403
37.49.236.50    00:02:28  748e.f8a3.8741  Ethernet1/54.403
37.49.236.51    00:03:45  588d.0913.63c0  Ethernet1/54.403
37.49.236.52    00:05:24  84b5.9c0c.5b60  Ethernet1/54.403
37.49.236.53    00:14:39  4c16.fc05.c8ad  Ethernet1/54.403
37.49.236.55    00:03:50  54e0.32c9.4fc0  Ethernet1/54.403
37.49.236.57    00:08:53  407c.7d9c.abda  Ethernet1/54.403
37.49.236.58    00:15:22  cce1.9468.985f  Ethernet1/54.403
37.49.236.60    00:11:57  7483.ef96.41be  Ethernet1/54.403
37.49.236.63    00:09:58  10e8.78b0.52ef  Ethernet1/54.403
37.49.236.64    00:09:21  0004.96a6.cd15  Ethernet1/54.403
37.49.236.65    00:09:54  00fe.c85d.2d05  Ethernet1/54.403
37.49.236.66    00:08:40  0209.c002.ad8a  Ethernet1/54.403
37.49.236.67    00:01:35  44aa.5097.f76d  Ethernet1/54.403
37.49.236.68    00:02:18  0024.38a6.0600  Ethernet1/54.403
37.49.236.69    00:06:20  d818.d313.f16e  Ethernet1/54.403
37.49.236.71    00:06:38  5c5e.ab0a.3469  Ethernet1/54.403
37.49.236.72    00:09:24  70e4.221e.b8e8  Ethernet1/54.403
37.49.236.74    00:02:27  788a.2041.3ab6  Ethernet1/54.403
37.49.236.76    00:04:54  c88d.8343.3196  Ethernet1/54.403
37.49.236.77    00:08:51  1418.7739.742d  Ethernet1/54.403
37.49.236.78    00:07:24  0024.c4e2.bd19  Ethernet1/54.403
37.49.236.79    00:12:46  ec38.737c.582b  Ethernet1/54.403
37.49.236.85    00:08:06  045c.6ca6.a459  Ethernet1/54.403
37.49.236.86    00:12:50  44ec.ce4f.241a  Ethernet1/54.403
37.49.236.87    00:09:39  327c.5eef.012e  Ethernet1/54.403
37.49.236.88    00:05:15  70db.98bd.c594  Ethernet1/54.403
37.49.236.89    00:06:15  f6a7.3936.caaa  Ethernet1/54.403
37.49.236.90    00:05:14  48f8.db63.f0f3  Ethernet1/54.403
37.49.236.91    00:13:55  000c.29d5.7bd0  Ethernet1/54.403
37.49.236.92    00:08:31  78ba.f963.5b26  Ethernet1/54.403
37.49.236.94    00:08:54  0cc4.7aea.ce16  Ethernet1/54.403
37.49.236.95    00:05:12  84ad.5891.e350  Ethernet1/54.403
37.49.236.96    00:04:39  ac4b.c885.e7c5  Ethernet1/54.403
37.49.236.97    00:08:47  5087.891c.127a  Ethernet1/54.403
37.49.236.98    00:09:46  02fa.cade.9801  Ethernet1/54.403
37.49.236.99    00:12:48  78ba.f97c.e6aa  Ethernet1/54.403
37.49.236.100   00:03:21  9ce1.7662.a0e0  Ethernet1/54.403
37.49.236.101   00:05:01  f866.f20b.8852  Ethernet1/54.403
37.49.236.102   00:09:15  ac78.d13e.b045  Ethernet1/54.403
37.49.236.103   00:11:27  b8ce.f604.6a19  Ethernet1/54.403
37.49.236.104   00:01:38  748e.f8a7.3f81  Ethernet1/54.403
37.49.236.105   00:06:20  2899.3aa6.2447  Ethernet1/54.403
37.49.236.107   00:00:53  f4cc.5546.b295  Ethernet1/54.403
37.49.236.111   00:00:32  70b3.d5e6.104c  Ethernet1/54.403
37.49.236.112   00:16:16  045c.6ccb.673a  Ethernet1/54.403
37.49.236.113   00:02:52  74a0.2f7b.7281  Ethernet1/54.403
37.49.236.114   00:02:01  748e.f838.ee87  Ethernet1/54.403
37.49.236.115   00:02:33  748e.f8a5.5d07  Ethernet1/54.403
37.49.236.116   00:02:45  5254.00d7.42a7  Ethernet1/54.403
37.49.236.117   00:02:33  a8d0.e55c.dc00  Ethernet1/54.403
37.49.236.118   00:16:49  8ae0.f34f.f822  Ethernet1/54.403
37.49.236.119   00:05:01  5c5e.ab08.f8c0  Ethernet1/54.403
37.49.236.120   00:09:27  40a6.774a.b7c3  Ethernet1/54.403
37.49.236.121   00:15:37  88e6.4bce.9423  Ethernet1/54.403
37.49.236.122   00:06:15  6cb2.ae7b.4541  Ethernet1/54.403
37.49.236.125   00:14:04  985d.826e.8929  Ethernet1/54.403
37.49.236.129   00:09:27  001b.0de5.8240  Ethernet1/54.403
37.49.236.131   00:13:31  b48a.5f5c.50b3  Ethernet1/54.403
37.49.236.132   00:16:44  84c1.c173.dbe1  Ethernet1/54.403
37.49.236.133   00:15:01  0015.171e.f2a9  Ethernet1/54.403
37.49.236.134   00:03:36  7483.ef36.ebeb  Ethernet1/54.403
37.49.236.135   00:11:00  70db.985e.8f86  Ethernet1/54.403
37.49.236.137   00:01:31  fc33.4211.3420  Ethernet1/54.403
37.49.236.138   00:08:09  6487.8858.e2b8  Ethernet1/54.403
37.49.236.139   00:16:15  001d.b5cc.5a41  Ethernet1/54.403
37.49.236.141   00:08:59  78ba.f912.7179  Ethernet1/54.403
37.49.236.143   00:01:42  748e.f8a8.9541  Ethernet1/54.403
37.49.236.144   00:09:29  7c31.0e15.70e7  Ethernet1/54.403
37.49.236.148   00:06:49  40de.adcc.2c1a  Ethernet1/54.403
37.49.236.149   00:16:21  7483.ef95.de98  Ethernet1/54.403
37.49.236.150   00:09:22  78ba.f928.d80d  Ethernet1/54.403
37.49.236.153   00:12:37  70e4.2236.573c  Ethernet1/54.403
37.49.236.155   00:02:25  748e.f8a5.df41  Ethernet1/54.403
37.49.236.156   00:09:24  8478.ac5e.9591  Ethernet1/54.403
37.49.236.157   00:10:37  00a7.425b.83d3  Ethernet1/54.403
37.49.236.159   00:07:37  7850.7c29.c235  Ethernet1/54.403
37.49.236.162   00:10:31  0011.92ce.a680  Ethernet1/54.403
37.49.236.165   00:05:14  80b5.75f2.5602  Ethernet1/54.403
37.49.236.166   00:10:32  30b6.4fcd.93a9  Ethernet1/54.403
37.49.236.167   00:07:54  5c5e.ab02.2060  Ethernet1/54.403
37.49.236.168   00:02:01  f4a7.3911.e0c2  Ethernet1/54.403
37.49.236.171   00:15:20  b0a8.6e78.014a  Ethernet1/54.403
37.49.236.173   00:15:59  0022.836e.7ff1  Ethernet1/54.403
37.49.236.174   00:09:30  d404.ffd8.33f2  Ethernet1/54.403
37.49.236.177   00:18:16  6c9c.ed0e.5c3b  Ethernet1/54.403
37.49.236.179   00:08:36  885a.925b.0902  Ethernet1/54.403
37.49.236.181   00:09:20  c003.8086.9909  Ethernet1/54.403
37.49.236.182   00:02:33  fcbd.673c.010b  Ethernet1/54.403
37.49.236.184   00:09:54  701f.53d0.29c3  Ethernet1/54.403
37.49.236.185   00:09:17  08ec.f527.79c8  Ethernet1/54.403
37.49.236.186   00:09:54  e4c7.22a3.e949  Ethernet1/54.403
37.49.236.187   00:02:31  0024.38a4.fb00  Ethernet1/54.403
37.49.236.190   00:13:57  bc5f.f4e7.a4ec  Ethernet1/54.403
37.49.236.191   00:08:15  807f.f84e.79cf  Ethernet1/54.403
37.49.236.192   00:10:33  ae78.d13e.a863  Ethernet1/54.403
37.49.236.193   00:14:06  44ec.cef5.ac5e  Ethernet1/54.403
37.49.236.199   00:07:20  0022.83dd.77c1  Ethernet1/54.403
37.49.236.201   00:09:30  288a.1c61.f240  Ethernet1/54.403
37.49.236.202   00:08:24  488f.5a64.eb34  Ethernet1/54.403
37.49.236.203   00:08:37  c8fe.6a7b.dac6  Ethernet1/54.403
37.49.236.204   00:07:23  0478.6601.c100  Ethernet1/54.403
37.49.236.205   00:09:13  008a.96c9.1cac  Ethernet1/54.403
37.49.236.206   00:05:13  048c.1651.5601  Ethernet1/54.403
37.49.236.207   00:07:57  40a6.779c.22c6  Ethernet1/54.403
37.49.236.210   00:09:24  40ce.2454.18d2  Ethernet1/54.403
37.49.236.211   00:06:02  1402.ec79.c8c9  Ethernet1/54.403
37.49.236.214   00:07:48  a0f3.e4bf.13b0  Ethernet1/54.403
37.49.236.215   00:09:23  10f3.1141.0738  Ethernet1/54.403
37.49.236.217   00:09:23  0c81.2692.5be1  Ethernet1/54.403
37.49.236.218   00:10:00  00ee.abf8.1105  Ethernet1/54.403
37.49.236.220   00:03:06  44aa.508b.f205  Ethernet1/54.403
37.49.236.221   00:12:36  e45d.3705.9fc1  Ethernet1/54.403
37.49.236.224   00:03:55  0075.af00.af02  Ethernet1/54.403
37.49.236.227   00:14:48  0c81.2649.8d40  Ethernet1/54.403
37.49.236.228   00:14:21  c003.806e.500e  Ethernet1/54.403
37.49.236.230   00:15:20  88e6.4bc9.001a  Ethernet1/54.403
37.49.236.233   00:06:33  0001.2e2b.d207  Ethernet1/54.403
37.49.236.239   00:09:24  0032.17a6.9020  Ethernet1/54.403
37.49.236.241   00:06:03  f46e.95a6.ea15  Ethernet1/54.403
37.49.236.242   00:06:25  609c.9fde.7015  Ethernet1/54.403
37.49.236.243   00:15:25  4c5e.0c13.b8a9  Ethernet1/54.403
37.49.236.244   00:03:56  7483.ef37.f0f1  Ethernet1/54.403
37.49.236.246   00:15:04  0014.f246.0f19  Ethernet1/54.403
37.49.236.250   00:10:03  da6b.9c17.d7be  Ethernet1/54.403
37.49.236.251   00:10:59  4eb5.74e1.28ee  Ethernet1/54.403
37.49.237.2     00:00:37  d818.d391.9fc0  Ethernet1/54.403
37.49.237.3     00:13:08  f6cc.554b.1061  Ethernet1/54.403
37.49.237.5     00:12:45  f4cc.5583.71c5  Ethernet1/54.403
37.49.237.6     00:15:23  286f.7f7f.8040  Ethernet1/54.403
37.49.237.10    00:04:36  0026.0bd3.b820  Ethernet1/54.403
37.49.237.11    00:08:17  008a.96c8.1024  Ethernet1/54.403
37.49.237.14    00:17:32  0007.4333.fdc0  Ethernet1/54.403
37.49.237.16    00:10:04  00c1.6446.1968  Ethernet1/54.403
37.49.237.20    00:10:08  d46d.5066.507e  Ethernet1/54.403
37.49.237.21    00:10:59  001b.21d9.31d0  Ethernet1/54.403
37.49.237.22    00:05:39  00a7.4255.f3a4  Ethernet1/54.403
37.49.237.27    00:09:30  6c9c.ed32.3c0a  Ethernet1/54.403
37.49.237.30    00:00:04  b033.a66a.0015  Ethernet1/54.403
37.49.237.32    00:09:18  cc16.7eb0.4a32  Ethernet1/54.403
37.49.237.34    00:12:41  045c.6ca5.d9c4  Ethernet1/54.403
37.49.237.35    00:01:17  182a.d376.8479  Ethernet1/54.403
37.49.237.36    00:09:24  cc1a.faeb.1fa0  Ethernet1/54.403
37.49.237.38    00:08:20  c067.af49.985c  Ethernet1/54.403
37.49.237.39    00:16:43  706d.15ea.6e07  Ethernet1/54.403
37.49.237.41    00:15:20  4cbc.48d6.dacb  Ethernet1/54.403
37.49.237.43    00:09:16  bc4a.568c.d130  Ethernet1/54.403
37.49.237.46    00:13:49  10e8.7859.9159  Ethernet1/54.403
37.49.237.47    00:05:22  9ce1.76e2.c830  Ethernet1/54.403
37.49.237.48    00:08:48  84b5.9c0f.f7f2  Ethernet1/54.403
37.49.237.49    00:02:58  3c94.d5cc.a7c9  Ethernet1/54.403
37.49.237.50    00:02:09  2899.3a61.d9b5  Ethernet1/54.403
37.49.237.51    00:02:10  d867.d97d.9e8b  Ethernet1/54.403
37.49.237.52    00:03:28  0017.a37b.9680  Ethernet1/54.403
37.49.237.55    00:04:31  3c8c.93ea.b9cc  Ethernet1/54.403
37.49.237.58    00:06:41  90e2.ba28.b201  Ethernet1/54.403
37.49.237.59    00:03:41  d849.0bb7.0545  Ethernet1/54.403
37.49.237.63    00:08:44  444c.a845.f8eb  Ethernet1/54.403
37.49.237.64    00:17:22  5087.8938.9999  Ethernet1/54.403
37.49.237.65    00:08:53  d46d.506c.615c  Ethernet1/54.403
37.49.237.66    00:05:14  f063.f975.a609  Ethernet1/54.403
37.49.237.69    00:13:30  fc0a.81f9.c32d  Ethernet1/54.403
37.49.237.70    00:07:58  6687.8866.62e4  Ethernet1/54.403
37.49.237.71    00:18:34  de38.e1fe.6ae4  Ethernet1/54.403
37.49.237.72    00:10:19  3c61.04bd.bf19  Ethernet1/54.403
37.49.237.73    00:18:06  18e8.294e.da39  Ethernet1/54.403
37.49.237.75    00:03:35  748e.f8a4.8c01  Ethernet1/54.403
37.49.237.76    00:15:03  0021.5908.31c5  Ethernet1/54.403
37.49.237.77    00:05:13  7819.f730.57c1  Ethernet1/54.403
37.49.237.79    00:08:28  b8c2.53d4.946b  Ethernet1/54.403
37.49.237.81    00:07:53  0a00.051e.e5c8  Ethernet1/54.403
37.49.237.83    00:07:03  108c.cf1d.4cb2  Ethernet1/54.403
37.49.237.84    00:02:30  5cb2.aebf.2384  Ethernet1/54.403
37.49.237.86    00:13:25  0896.ad67.0b22  Ethernet1/54.403
37.49.237.87    00:13:04  d867.d934.4064  Ethernet1/54.403
37.49.237.88    00:13:06  001c.73d6.1968  Ethernet1/54.403
37.49.237.90    00:16:45  0204.7321.c9fa  Ethernet1/54.403
37.49.237.94    00:16:09  288a.1c62.c7c4  Ethernet1/54.403
37.49.237.97    00:09:21  a89d.2120.f202  Ethernet1/54.403
37.49.237.98    00:09:21  a80c.0d73.7c01  Ethernet1/54.403
37.49.237.100   00:00:13  985d.82b7.2cd1  Ethernet1/54.403
37.49.237.102   00:09:54  44f4.7717.d032  Ethernet1/54.403
37.49.237.103   00:01:43  0004.96a7.2706  Ethernet1/54.403
37.49.237.104   00:18:19  80a2.3598.18ff  Ethernet1/54.403
37.49.237.105   00:10:39  001c.73d6.190e  Ethernet1/54.403
37.49.237.106   00:09:08  00d7.8f55.6c04  Ethernet1/54.403
37.49.237.108   00:09:24  807f.f86a.0e37  Ethernet1/54.403
37.49.237.109   00:03:47  fc33.421f.400d  Ethernet1/54.403
37.49.237.110   00:01:48  e443.4b27.3462  Ethernet1/54.403
37.49.237.112   00:05:13  58f9.8728.3d6c  Ethernet1/54.403
37.49.237.120   00:07:16  fc33.4215.7025  Ethernet1/54.403
37.49.237.122   00:09:46  000f.5307.5fe4  Ethernet1/54.403
37.49.237.123   00:09:46  f87b.2073.3c22  Ethernet1/54.403
37.49.237.124   00:09:09  008a.96aa.b814  Ethernet1/54.403
37.49.237.126   00:04:05  0896.ad39.be1a  Ethernet1/54.403
37.49.237.130   00:06:00  00c1.6433.9234  Ethernet1/54.403
37.49.237.131   00:07:49  94f7.ad4f.6aa7  Ethernet1/54.403
37.49.237.133   00:12:18  0ef6.aecc.8dd6  Ethernet1/54.403
37.49.237.135   00:09:55  7ce2.cad3.c8e6  Ethernet1/54.403
37.49.237.136   00:02:12  7ce2.cad2.011c  Ethernet1/54.403
37.49.237.137   00:01:22  7483.ef6b.dce3  Ethernet1/54.403
37.49.237.144   00:14:29  327c.5eef.215e  Ethernet1/54.403
37.49.237.146   00:14:04  4055.392d.1a81  Ethernet1/54.403
37.49.237.147   00:08:52  5c45.27d0.2e05  Ethernet1/54.403
37.49.237.151   00:03:15  e4fc.824f.8c5c  Ethernet1/54.403
37.49.237.152   00:16:19  08ec.f546.4754  Ethernet1/54.403
37.49.237.153   00:02:47  a80c.0d72.cf8c  Ethernet1/54.403
37.49.237.154   00:13:57  d0dd.491f.1fca  Ethernet1/54.403
37.49.237.155   00:10:46  fcbd.67cf.1835  Ethernet1/54.403
37.49.237.156   00:10:57  fc99.4707.8930  Ethernet1/54.403
37.49.237.157   00:00:18  2899.3a06.5533  Ethernet1/54.403
37.49.237.158   00:06:30  fc0a.81fe.1960  Ethernet1/54.403
37.49.237.160   00:12:31  0027.0dfd.4b00  Ethernet1/54.403
37.49.237.163   00:10:17  9ccc.83c9.d84a  Ethernet1/54.403
37.49.237.164   00:04:06  9ce1.7615.90e3  Ethernet1/54.403
37.49.237.165   00:09:24  c0d6.8205.9683  Ethernet1/54.403
37.49.237.166   00:01:30  ec38.73ad.7439  Ethernet1/54.403
37.49.237.170   00:17:18  cc2d.e00f.25fc  Ethernet1/54.403
37.49.237.171   00:15:19  d0dd.49a6.d741  Ethernet1/54.403
37.49.237.173   00:03:40  0896.ad23.31be  Ethernet1/54.403
37.49.237.175   00:11:14  fcbd.679d.304d  Ethernet1/54.403
37.49.237.176   00:13:03  4271.8393.6cee  Ethernet1/54.403
37.49.237.179   00:10:14  5a00.bb01.905b  Ethernet1/54.403
37.49.237.183   0.005925  7483.ef73.65e3  Ethernet1/54.403
37.49.237.184   00:09:12  8890.0984.4c31  Ethernet1/54.403
37.49.237.186   00:01:09  b026.8079.2420  Ethernet1/54.403
37.49.237.187   00:00:28  807f.f879.4ddb  Ethernet1/54.403
37.49.237.191   00:08:41  44ec.cef4.5848  Ethernet1/54.403
37.49.237.193   00:14:46  8843.e13d.b7ff  Ethernet1/54.403
37.49.237.194   00:10:40  0022.1963.eac0  Ethernet1/54.403
37.49.237.197   00:10:11  001d.b5a0.07c2  Ethernet1/54.403
37.49.237.198   00:13:19  fc33.42fd.e4ef  Ethernet1/54.403
37.49.237.204   00:09:40  b4fb.e48e.0d68  Ethernet1/54.403
37.49.237.205   00:14:44  8071.1fc3.1301  Ethernet1/54.403
37.49.237.206   00:06:40  78ba.f920.a279  Ethernet1/54.403
37.49.237.209   00:14:14  8890.0971.7c4a  Ethernet1/54.403
37.49.237.211   00:12:29  0032.17a4.7814  Ethernet1/54.403
37.49.237.212   00:05:14  6008.1061.5edc  Ethernet1/54.403
37.49.237.214   00:18:13  0026.0bdc.aa80  Ethernet1/54.403
37.49.237.215   00:10:35  2899.3ad9.fa5c  Ethernet1/54.403
37.49.237.219   00:09:23  d46a.3565.1c2c  Ethernet1/54.403
37.49.237.225   00:09:07  b8ce.f652.e64d  Ethernet1/54.403
37.49.237.226   00:00:04  cc2d.e0bb.9554  Ethernet1/54.403
37.49.237.230   00:08:53  3c8c.934e.3005  Ethernet1/54.403
37.49.237.231   00:09:15  fc99.4715.1e10  Ethernet1/54.403
37.49.237.232   00:00:27  d8b1.2293.0535  Ethernet1/54.403
37.49.237.233   00:09:13  b026.8006.e58d  Ethernet1/54.403
37.49.237.236   00:09:30  fc0a.81fe.9715  Ethernet1/54.403
37.49.237.239   00:09:14  0015.5df0.6501  Ethernet1/54.403
37.49.237.245   00:00:10  a036.9f7b.e3f6  Ethernet1/54.403
37.49.237.246   00:00:10  a036.9f7b.e302  Ethernet1/54.403
37.49.237.247   00:01:27  a036.9f9b.7da2  Ethernet1/54.403
37.49.237.248   00:01:07  a036.9f7b.e0ee  Ethernet1/54.403
37.49.237.249   00:01:27  a036.9f9b.7d32  Ethernet1/54.403
37.49.237.250   00:04:24  a036.9f7b.e07e  Ethernet1/54.403
37.49.237.251   00:00:47  a036.9f9b.7c9e  Ethernet1/54.403
37.49.237.252   00:01:03  a036.9f9b.7786  Ethernet1/54.403
37.49.237.253   00:00:10  a036.9f9b.7cee  Ethernet1/54.403
37.49.237.254   00:00:10  a036.9f9b.7b92  Ethernet1/54.403
37.49.237.255   00:03:58  985d.82b7.2f6b  Ethernet1/54.403
37.49.238.1     00:09:22  78ba.f940.dc3a  Ethernet1/54.403
37.49.238.2     00:08:31  f8f2.1e7b.3f09  Ethernet1/54.403
37.49.238.3     00:01:08  e4fc.824e.a8df  Ethernet1/54.403
37.49.238.8     00:03:39  0896.ad24.8043  Ethernet1/54.403
37.49.238.9     00:05:13  78b4.6a21.2afd  Ethernet1/54.403
37.49.238.10    00:13:13  94bf.9435.9c55  Ethernet1/54.403
37.49.238.11    00:09:07  985d.82b7.29a3  Ethernet1/54.403
37.49.238.12    00:00:19  985d.82b7.70bf  Ethernet1/54.403
37.49.238.13    00:09:29  6412.2574.9507  Ethernet1/54.403
37.49.238.17    00:14:02  30b6.4f32.38a5  Ethernet1/54.403
37.49.238.19    00:10:42  c8fe.6a4d.9607  Ethernet1/54.403
37.49.238.20    00:05:13  9016.baa4.6a9b  Ethernet1/54.403
37.49.238.21    00:10:00  008a.962b.90ac  Ethernet1/54.403
37.49.238.22    00:14:06  20d8.0bee.b830  Ethernet1/54.403
37.49.238.23    00:09:24  6c9c.ed00.a10b  Ethernet1/54.403
37.49.238.29    00:13:07  649d.99b1.394b  Ethernet1/54.403
37.49.238.30    00:16:05  e8ed.f335.4cab  Ethernet1/54.403
37.49.238.32    00:04:53  8c1f.64ac.e022  Ethernet1/54.403
100.64.70.5     00:10:00  8cb6.4fe8.dfaa  Ethernet1/54.803
185.171.202.85     -      1eff.6dff.3eb9  Vlan50
185.171.202.245    -      0011.324e.9a71  Vlan50
193.38.250.2       -      2ab2.6f45.a77c  Vlan50
edge01.par9k#
edge01.par9k# show access-list
IP access list 50-anti-ddos-in
        statistics per-entry
        5000 deny udp any any eq 22 [match=307701366]
        5003 deny udp any eq ntp any lt 1024 [match=132627637]
        5004 deny udp any eq 443 185.171.202.92/32 [match=32]
        5005 deny udp any eq 443 185.171.202.93/32 [match=0]
        5007 deny udp any eq ntp any eq 22 [match=0]
        5008 deny udp any eq 443 185.171.202.7/32 [match=0]
        5009 deny udp any eq 8006 185.171.202.92/32 [match=20]
        5010 permit udp 51.158.147.92/32 eq ntp 45.95.114.0/24 [match=22]
        5011 permit udp 51.158.147.92/32 eq ntp 45.158.76.0/24 [match=0]
        5012 permit udp 51.158.147.92/32 eq ntp 45.158.77.0/24 [match=0]
        5500 deny udp any eq ntp 45.95.114.0/24 [match=655805023]
        5501 deny udp any eq ntp 45.158.76.0/24 [match=156]
        5502 deny udp any eq ntp 45.158.77.0/24 [match=6652278]
        10000 permit ip any 5.8.249.0/24 [match=116860106]
        10001 permit ip any 41.71.228.0/23 [match=34610860]
        10002 permit ip any 45.13.116.0/24 [match=31964614]
        10003 permit ip any 45.95.114.0/24 [match=14807170199]
        10004 permit ip any 45.158.76.0/24 [match=133671025]
        10005 permit ip any 94.176.160.0/24 [match=29689945]
        10006 permit ip any 94.176.161.0/24 [match=10172706]
        10007 permit ip any 176.96.231.0/24 [match=116748741]
        10008 permit ip any 185.132.53.0/24 [match=95625137]
        10009 permit ip any 185.171.202.0/24 [match=46740339527]
        10010 permit ip any 193.38.250.0/24 [match=12928562073]
        10011 permit ip any 45.158.77.0/24 [match=3008845008]
        10012 permit ip any 45.154.96.0/24 [match=462110]
        10013 permit ip any 179.61.141.0/24 [match=0]
        15000 deny ip any any [match=114087793]
        16000 permit ip any any [match=50347]
IP access list copp-system-p-acl-auto-rp
        10 permit ip any 224.0.1.39/32
        20 permit ip any 224.0.1.40/32
IP access list copp-system-p-acl-bgp
        10 permit tcp any gt 1023 any eq bgp
        20 permit tcp any eq bgp any gt 1023
IPv6 access list copp-system-p-acl-bgp6
IP access list copp-system-p-acl-dhcp
        10 permit udp any eq bootpc any
        20 permit udp any neq bootps any eq bootps
IP access list copp-system-p-acl-dhcp-relay-response
        10 permit udp any eq bootps any
        20 permit udp any any eq bootpc
IPv6 access list copp-system-p-acl-dhcp6
        10 permit udp any eq 546 any
        20 permit udp any any eq 547
IPv6 access list copp-system-p-acl-dhcp6-relay-response
        10 permit udp any eq 547 any
        20 permit udp any any eq 546
IP access list copp-system-p-acl-eigrp
        10 permit eigrp any any
IPv6 access list copp-system-p-acl-eigrp6
IP access list copp-system-p-acl-ftp
        10 permit tcp any any eq ftp-data
        20 permit tcp any any eq ftp
        30 permit tcp any eq ftp-data any
        40 permit tcp any eq ftp any
IP access list copp-system-p-acl-hsrp
        10 permit udp any 224.0.0.0/24 eq 1985
IPv6 access list copp-system-p-acl-hsrp6
        10 permit udp any ff02::66/128 eq 2029
IP access list copp-system-p-acl-http
        10 permit tcp any eq www any
        20 permit tcp any any eq www
IP access list copp-system-p-acl-https
        10 permit tcp any eq 443 any
        20 permit tcp any any eq 443
IP access list copp-system-p-acl-icmp
        10 permit icmp any any echo
        20 permit icmp any any echo-reply
IPv6 access list copp-system-p-acl-icmp6
        10 permit icmp any any echo-request
IP access list copp-system-p-acl-igmp
        10 permit igmp any 224.0.0.0/3
MAC access list copp-system-p-acl-mac-cdp-udld-vtp
        10 permit any 0100.0ccc.cccc 0000.0000.0000
MAC access list copp-system-p-acl-mac-cfsoe
        10 permit any 0180.c200.000e 0000.0000.0000 0x8843
        20 permit any 0180.c200.000e 0000.0000.0000
MAC access list copp-system-p-acl-mac-dot1x
        10 permit any 0180.c200.0003 0000.0000.0000 0x888e
MAC access list copp-system-p-acl-mac-fcoe
        10 permit any any 0x8906
        20 permit any any 0x8914
MAC access list copp-system-p-acl-mac-l2-tunnel
        10 permit any any 0x8840
MAC access list copp-system-p-acl-mac-l3-isis
        10 permit any 0180.c200.0015 0000.0000.0000
        20 permit any 0180.c200.0014 0000.0000.0000
        30 permit any 0900.2b00.0005 0000.0000.0000
        40 permit any 0900.2b00.0004 0000.0000.0000
MAC access list copp-system-p-acl-mac-lacp
        10 permit any 0180.c200.0002 0000.0000.0000 0x8809
MAC access list copp-system-p-acl-mac-lldp
        10 permit any 0180.c200.000e 0000.0000.0000 0x88cc
MAC access list copp-system-p-acl-mac-sdp-srp
        10 permit any 0180.c200.000e 0000.0000.0000 0x3401
MAC access list copp-system-p-acl-mac-stp
        10 permit any 0100.0ccc.cccd 0000.0000.0000
        20 permit any 0180.c200.0000 0000.0000.0000
MAC access list copp-system-p-acl-mac-undesirable
        10 permit any any
IPv6 access list copp-system-p-acl-mld
        10 permit icmp any any mld-query
        20 permit icmp any any mld-report
        30 permit icmp any any mld-reduction
        40 permit icmp any any mldv2
IP access list copp-system-p-acl-msdp
        10 permit tcp any gt 1023 any eq 639
        20 permit tcp any eq 639 any gt 1023
IPv6 access list copp-system-p-acl-ndp
        10 permit icmp any any router-solicitation
        20 permit icmp any any router-advertisement
        30 permit icmp any any nd-ns
        40 permit icmp any any nd-na
IP access list copp-system-p-acl-ntp
        10 permit udp any any eq ntp
        20 permit udp any eq ntp any
IPv6 access list copp-system-p-acl-ntp6
IP access list copp-system-p-acl-openflow
        10 permit tcp any eq 6653 any
IP access list copp-system-p-acl-ospf
        10 permit ospf any any
IPv6 access list copp-system-p-acl-ospf6
        10 permit 89 any any
IP access list copp-system-p-acl-pim
        10 permit pim any 224.0.0.0/24
        20 permit udp any any eq pim-auto-rp
        30 permit ip any 224.0.0.13/32
IP access list copp-system-p-acl-pim-mdt-join
        10 permit udp any 224.0.0.13/32
IP access list copp-system-p-acl-pim-reg
        10 permit pim any any
IPv6 access list copp-system-p-acl-pim6
        10 permit pim any ff02::d/128
IPv6 access list copp-system-p-acl-pim6-reg
IP access list copp-system-p-acl-ptp
        10 permit udp any 224.0.1.129/32 eq 319
        20 permit udp any 224.0.1.129/32 eq 320
MAC access list copp-system-p-acl-ptp-l2
        10 permit any any 0x88f7
IP access list copp-system-p-acl-ptp-uc
        10 permit udp any any eq 319
        20 permit udp any any eq 320
IP access list copp-system-p-acl-radius
        10 permit udp any any eq 1812
        20 permit udp any any eq 1813
        30 permit udp any any eq 1645
        40 permit udp any any eq 1646
        50 permit udp any eq 1812 any
        60 permit udp any eq 1813 any
        70 permit udp any eq 1645 any
        80 permit udp any eq 1646 any
IPv6 access list copp-system-p-acl-radius6
IP access list copp-system-p-acl-rip
        10 permit udp any 224.0.0.0/24 eq rip
IPv6 access list copp-system-p-acl-rip6
        10 permit udp any ff02::9/64 eq 521
IP access list copp-system-p-acl-sftp
        10 permit tcp any any eq 115
        20 permit tcp any eq 115 any
IP access list copp-system-p-acl-snmp
        10 permit udp any any eq snmp
        20 permit udp any any eq snmptrap
        30 permit tcp any any eq 161
        40 permit tcp any any eq 162
IPv6 access list copp-system-p-acl-snmp6
IP access list copp-system-p-acl-ssh
        10 permit tcp any any eq 22
        20 permit tcp any eq 22 any
IPv6 access list copp-system-p-acl-ssh6
IP access list copp-system-p-acl-tacacs
        10 permit tcp any any eq tacacs
        20 permit tcp any eq tacacs any
IPv6 access list copp-system-p-acl-tacacs6
IP access list copp-system-p-acl-telnet
        10 permit tcp any any eq telnet
        20 permit tcp any any eq 107
        30 permit tcp any eq telnet any
        40 permit tcp any eq 107 any
IPv6 access list copp-system-p-acl-telnet6
IP access list copp-system-p-acl-tftp
        10 permit udp any any eq tftp
        20 permit udp any any eq 1758
        30 permit udp any eq tftp any
        40 permit udp any eq 1758 any
IPv6 access list copp-system-p-acl-tftp6
IP access list copp-system-p-acl-traceroute
        10 permit icmp any any ttl-exceeded
        20 permit icmp any any port-unreachable
        30 permit udp any any range 33434 33534
IP access list copp-system-p-acl-undesirable
        10 permit udp any any eq 1434
IP access list copp-system-p-acl-vpc
        10 permit udp any any eq 3200
IP access list copp-system-p-acl-vrrp
        10 permit ip any 224.0.0.18/32
IPv6 access list copp-system-p-acl-vrrp6
        10 permit ipv6 any ff02::12/128
IP access list customers
        20 permit ip 5.8.249.0/24 any [match=978310]
        21 permit ip 41.71.228.0/23 any [match=7430839]
        22 permit ip 45.13.116.0/24 any [match=23]
        23 permit ip 45.95.114.0/24 any [match=3280798]
        24 permit ip 45.158.76.0/24 any [match=59433]
        25 permit ip 94.176.160.0/24 any [match=17839574]
        26 permit ip 94.176.161.0/24 any [match=30]
        27 permit ip 176.96.231.0/24 any [match=1715702]
        28 permit ip 185.132.53.0/24 any [match=87145749]
        29 permit ip 185.171.202.0/24 any [match=34464180449]
        30 permit ip 193.38.250.0/24 any [match=14582029009]
        31 permit ip 45.158.77.0/24 any [match=20960]
        32 permit ip 45.154.96.0/24 any [match=272177]
        33 permit ip 179.61.141.0/24 any [match=0]
        99 deny ip any any [match=23846364]
        100 permit ip any any [match=28997833434]
IP access list extended
edge01.par9k#
The server is directly connected to VLAN 50, ports are in access mode.
pman
Beginner
Why you configure multiple subnets on the same vlan  (vlan 50)?
Is there a particular reason you decided this was the right architecture for you?
why not to create a interface vlan for each subnet?
VLANS is a concept of LAYER 2 components (like switches)
IP subnets are L3
recommends a 1:1 ratio VLAN to SUBNET
Maybe you should think about redesigning your topology.
of course technically it is possible but not recommended.
Thanks for update.
We have multiples subnet on VLAN because all rack servers must get a IP in all pools. (datacenter installation, clients have /32 IPs)
For information, today i'have tried to put prefix on another VLAN and it work.
But if I put prefix on another VLAN, my customer will not able to use old IP 185.171.202.0/24.
@pman
Any idea?
pman
Beginner
If I understand correctly you created a new VLAN  with network of 185.171.202.0/24 and assign servers to the new VLAN?
what exactly is not working, the servers left in VLAN50 in network 185.171.202.0/24 not working?
If so it means that You need to migrate all the servers that were left in VLAN 50 with network of 185.171.202.0/24 to the new vlan and delete the secondary 185.171.202.0/24 form VLAN 50
