Cisco Security Certification Replacement for CCSP
Hello All,
Can someone please tell me if the CCSP certification has been retired and what it has actually been replaced by? Also, what are the requirements to becoming professionally certified in security?
Unfortuantely, Cisco's website doesn't make it very clear.
Cheers
Carlton
Jennifer Halim
Correct, CCSP has been retired and the replacement is called CCNP Security.
Here is the URL for your reference:
http://www.cisco.com/web/learning/le3/le2/le37/le9/learning_certification_type_home.html
