Configuration for two ISP T1s
kingken
I need to distribute my server LAN (192.168.102.x) and desktop LAN traffic (192.168.100.x) to two of our separate ISP T1s on my 2621 router. I don't want load sharing or any dedundancy (at least not yet). I'm not sure how to go about configuring the two separate NATs or ip routes but I read on the Cisco site somewhere to use route-map and access-list. Can someone verify my router configuration below. Thanks!
-Ken
version 12.2
service timestamps debug datetime localtime
service timestamps log datetime localtime
service password-encryption
hostname starcisco
ip subnet-zero
ip audit notify log
ip audit po max-events 100
interface FastEthernet0/0
description Connection to Desktop&Server LAN
ip address 192.168.100.254 255.255.255.0
ip nat inside
duplex auto
speed auto
interface Serial0/0
no ip address
encapsulation frame-relay IETF
frame-relay lmi-type ansi
interface Serial0/0.1 point-to-point
description Connection to Internet (ISP1 for Desktop LAN)
ip address 1.1.1.2 255.255.255.252
ip access-group 104 in
ip nat outside
frame-relay interface-dlci 808
interface FastEthernet0/1
description Connection to DMZ
ip address 1.2.3.4 255.255.255.224
ip access-group 102 in
duplex auto
speed auto
interface Serial0/1
description Connection to Internet (ISP2 for Server LAN)
ip address 2.2.2.2 255.255.255.248
ip access-group 105 in
ip nat outside
! NAT with route map and nat pool
!ip nat pool isp1-space 1.1.1.3 1.1.1.4 prefix-length 24
!ip nat pool isp2-space 2.2.2.3 2.2.2.4 prefix-length 24
ip nat inside source route-map isp1-map pool isp1-space
ip nat inside source route-map isp2-map pool isp2-space
route-map isp1-map permit 10
match ip address 1
match interface Serial0/1
route-map isp2-map permit 10
match ip address 2
match interface Serial0/0.1
! internal static NAT mappings to servers
! like email server and vpn server
ip nat inside source static 192.168.102.164 2.2.2.5 route-map isp2-map
ip nat inside source static 192.168.102.165 2.2.2.6 route-map isp2-map
! default internet routes
ip route 0.0.0.0 0.0.0.0 Serial0/0.1
ip route 0.0.0.0 0.0.0.0 Serial0/1
! static routes to interal desktop/serve LAN
ip route 192.168.0.0 255.255.255.0 FastEthernet0/0
ip route 192.168.102.0 255.255.255.0 FastEthernet0/0
! rules for source match
! Desktop LAN
access-list 1 permit 192.168.0.0 0.0.255.255
! Server LAN
access-list 2 permit 192.168.102.0 0.0.0.255
! firewall ACLs
access-list 104 .....
access-list 105 ....
end
mhussein
Level 4
Level 4
I don't think route-maps are applicable here unless you are using policy routing, redistribution, or BGP.
Not sure if you can use a "route-map" in this line:
ip nat inside source route-map isp1-map pool isp1-space to me it doesn't seem to be a valid command, someone else may verify this.
I think it should be something like:
ip nat inside source list 1 pool isp1-space overload
access-list 1 permit 192.168.100.0 0.0.0.255
This will NAT the desktop ip addresses to ISP1 ip addresses. The overload is needed since the serial interface is on 255.255.255.252 network, one usable ip address which is the serial's ip itself!
And also the pool should be:
ip nat pool isp1-space 1.1.1.3 1.1.1.3 prefix-length 30
where one ip address 1.1.1.3 will be uses/overloaded, and the subnet mask is 30 bits=255.255.255.252
Similar configuration can be applied to ISP2 NAT, except that you have 5 additional ip addresses that you can assign statically to your DMZ hosts. The prefix-length should be 29 (the subnet maske on ISP2's serial interface is 29-bits=255.255.255.248)
The last 2 static NAT commands should be without the route-map isp2-map trailer:
Mustafa
I disagree. You actually will need two sets of route maps here. One set to do the policy routing based on source IP so that outbound traffic (to the Internet) coming into the router from your servers will go to the server ISP and traffic from your users will go to the user ISP.
Then you need a second set of route-maps so that the correct translations are applied to outbound traffic based on which interface they are exiting. This set might be considered optional, assuming the static mappings already defined for incoming traffic from the Internet set up the correct overrides. However, you'll need them if you want all traffic from your servers, including transactions such as DNS lookups or NTP packets which originate on the server, to use the server ISP.
Unfortunately, I don't have time to go over your configs in detail and make the necessary changes (I have to work for a living and free advice is limited to what I can provide off the top of my head), but the above should be enough to get you headed in the right direction.
Good luck and have fun!
Vincent C. Jones
www.networkingunlimited.com
