02-28-2013 10:49 AM - edited 03-03-2019 06:59 AM
Hi, I`m sort of new here, and currently working on my bachelor theses. I`ve done lots of searching on various websites, but still confused about terms: Congestion window and Transmission window. Can anybody help on this topic, PLEASE?
03-02-2013 06:50 PM
Hello Radim.
The transmission window is the amount of data which can be in transit between two endpoints at a given time. Because of the reliable nature of TCP, a TCP sender can transmit only a limited amount of data before it must receive an acknowledgement from the receiver; this is to ensure that any lost segments can be retransmitted efficiently.
The congestion window is a variable that directly affects the transmission window, this is a value advertise by the send to the TCP peer receiver .
At any given time, the send must not send data when a congestion flag is set in the TCP header.
I hope this helps.
Wilson B
03-08-2013 09:50 AM
Hi Wilson,
Sorry for late reply, but yes, that helped. By the time I saw yr answer I`ve read some info about it and got a small picture about the windows. As i can see, you`re sort of proffesional in this area. Do you have any experience with Linux? regarding TCP and networking.
I really appreciate your help.
Radim H.
03-04-2013 08:25 AM
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Have you reviewed the RFCs?
