Connecting 2960 switch to HG532 ADSL modem
Ahmed Nadi
Dears,
i am trying to connect 2960-8 port siwitch to HG532 adsl modem but i need some help in the needed configuration on both modem and switch
i need to know the cabling type between the modem and the cisco switch (straight-cross) ?
i have tried to use the switch without configuration but the users connected to the switch can't go out to the internet although i can reach internet using wifi
setup
ADSL modem ---> 2960 switch ---> LAN users
Alan Ng'ethe
Level 3
Level 3
Should be a straight-through cable. Check the document for some guidance.
EchoLife HG532 Home Gateway
Just ensure the switch is plugged in to the LAN side, and that DHCP is enabled on the router.
Remember to rate helpful posts and/or mark as a solution if your issue is resolved.
