Connecting two 1751 w/serial interfaces
dal
I am attempting to connect to 1751 routers w/serial interfaces via t1 line. Router "A" (host side) is identical to router "B" remote side. I want to keep them on the same subnet for simplicity purposes. I have performed this feat with csu/dsu modules in the past, but never with serial interfaces. Host side has an internet gateway seperate from the router itself - which the remote side will need access to also. For the life of me I cannot figure out what I am doing wrong. This is the configuration from router "A", router "B's" configuration is identical except for the BVI 1 IP address is x.x.x.22 instead of x.x.x.21. Any help is greatly appreciated.
Using 876 out of 29688 bytes
version 12.2
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname Cisco1
enable password xxxx
memory-size iomem 25
ip subnet-zero
no ip domain lookup
bridge irb
interface FastEthernet0/0
description connected to EthernetLAN_1
no ip address
no keepalive
speed auto
bridge-group 1
interface Serial0/0
description connected to CiscoB
ip unnumbered FastEthernet0/0
bridge-group 1
interface BVI1
ip address 192.168.0.21 255.255.255.0
router rip
version 2
network 192.168.0.0
no auto-summary
ip classless
no ip http server
snmp-server community public RO
snmp-server enable traps tty
bridge 1 protocol ieee
line con 0
exec-timeout 0 0
password xxxx
login
line aux 0
line vty 0 4
password xxxx
login
no scheduler allocate
end
30 Replies 30
I ran the debug command - take a look and see what you think. Thanks
debug serial interface
Serial network interface debugging is on
CiscoA#
*Mar 1 00:18:03.731: Illegal HDLC serial type code 777, PC=0x800140CC
*Mar 1 00:18:05.227: Serial0/0: HDLC myseq 107, mineseen 0, yourseen 0, line do
wn
*Mar 1 00:18:06.227: Serial0/0: attempting to restart
*Mar 1 00:18:06.227: PowerQUICC(0/0): DCD is up.
*Mar 1 00:18:13.731: Illegal HDLC serial type code 777, PC=0x800140CC
*Mar 1 00:18:15.227: Serial0/0: HDLC myseq 108, mineseen 0, yourseen 0, line do
wn
*Mar 1 00:18:23.731: Illegal HDLC serial type code 776, PC=0x800140CC
*Mar 1 00:18:23.731: Illegal HDLC serial type code 777, PC=0x800140CC
*Mar 1 00:18:25.227: Serial0/0: HDLC myseq 109, mineseen 0, yourseen 0, line do
wn
*Mar 1 00:18:33.731: Illegal HDLC serial type code 777, PC=0x800140CC
*Mar 1 00:18:35.227: Serial0/0: HDLC myseq 110, mineseen 0, yourseen 0, line do
wn
*Mar 1 00:18:36.227: Serial0/0: attempting to restart
*Mar 1 00:18:36.227: PowerQUICC(0/0): DCD is up.
*Mar 1 00:18:43.731: Illegal HDLC serial type code 777, PC=0x800140CC
*Mar 1 00:18:45.227: Serial0/0: HDLC myseq 111, mineseen 0, yourseen 0, line do
wn
*Mar 1 00:18:53.731: Illegal HDLC serial type code 777, PC=0x800140CC
*Mar 1 00:18:55.227: Serial0/0: HDLC myseq 112, mineseen 0, yourseen 0, line do
wn
*Mar 1 00:19:03.731: Illegal HDLC serial type code 777, PC=0x800140CC
*Mar 1 00:19:05.227: Serial0/0: HDLC myseq 113, mineseen 0, yourseen 0, line do
wn
*Mar 1 00:19:06.227: Serial0/0: attempting to restart
*Mar 1 00:19:06.227: PowerQUICC(0/0): DCD is up.
*Mar 1 00:19:13.731: Illegal HDLC serial type code 777, PC=0x800140CC
*Mar 1 00:19:15.227: Serial0/0: HDLC myseq 114, mineseen 0, yourseen 0, line do
wn
*Mar 1 00:19:23.731: Illegal HDLC serial type code 776, PC=0x800140CC
*Mar 1 00:19:23.731: Illegal HDLC serial type code 777, PC=0x800140CC
*Mar 1 00:19:25.227: Serial0/0: HDLC myseq 115, mineseen 0, yourseen 0, line do
wn
