06-08-2005 06:59 AM - edited 03-02-2019 11:02 PM
Is there a way to convert a Catalyst 2950 to a hub? I need to sniffer packets, and do not have a hub but a switch.
06-08-2005 07:08 AM
just make all the ports as half duplex.
06-08-2005 07:19 AM
Unfortunately, there is no way to this this fully. You can sniff a limited number of ports (can't remember exactly how many in the 2950, but I think it's 4 ports) using SPAN. Look for the monitor session command in the documentation. You can monitor the uplink, and that would give you most of the traffic.
Kevin Dorrell
Luxembourg
06-08-2005 04:14 PM
Hi Kevin,
Thanks for the note. But I wasn't exactly looking for switchport port analyzers. In fact, I have a core switch already doing SPAN, and I want those monitored sessions to be redirected to a hub so that I can connect different type of sniffers going to that hub. Since I have no hubs to start with, I will use what I have which is a Catalyst 2950.
Any idea on how to convert a switch into a hub?
06-08-2005 04:34 PM
The one thing that swithes do is mac-learning that sets them apart from Hubs. There is no support for disabling mac-learning in these switches today . If there was , you can turn a switch into a hub. AFAIK , you cannot turn 2950 into a hub , i.e to say you can not disable mac-learning.
thanks
Salman Z.
06-08-2005 05:35 PM
Here's what i think u could do..
get a mac-address flooding tool. ie. dsniff, macof.. when u flood the cam table of the switch with bogus mac-address, fill the cam table to the brim, then the switch will start acting like a hub.
If the switch can't learn anymore mac-address, (since it's filled up with bogus macs) it'll start forwarding incoming packets out all ports. There u go, u hv a hub. ;)
06-09-2005 06:09 AM
Don't you think it would be much more effective to spend 10 USD for a noname 8-port hub?
Milan
05-12-2015 09:17 AM
Kevin,
Why do you think it should be this way? I think I just did this (on a 3550 series switch, notably - but still).
Here's the CLI code:
interface VLAN2
no ip directed-broadcast
no ip route-cache
shutdown
interface range Fa0/1-3
switchport access vlan 2
switchport mode trunk
Details:
http://stackoverflow.com/questions/21507279/how-to-convert-cisco-switch-to-hub
05-12-2015 12:26 PM
That still makes it a switch, not a hub.
Once a switch sees a frame coming into a port, it observes the source MAC address in the frame and associates that MAC address with that port. When it has a frame to forward to that MAC address it will forward it to that port only. It is still acting as a transparent bridge. A port will not transmit frames destined to any MAC addresses the switch has seen on other ports.
The characteristic of a hub is it will forward all frames to all ports except the one it received it on.
Kevin
05-12-2015 12:29 PM
Actually, I have just thought of something that might work, but on one VLAN only ... declare the VLAN as a SPAN VLAN. I believe that disables learning for that VLAN. I've not tried it, but I think it should work.
Kevin
