Cookies and ?
liamwalk
Can somebody please remind me of things to check if you get a ? under cookies and the CiscoWorks logon screen does not appear.....
mustafa.mail
If you are using Netscape then check in Edit---> Preference---> advance --> accept all coockies.
If you are using IE then check Internet Properties--->Privacy--->Accept All Coockies.
Best regards,
Mustafa
The logon screen either appears with the cookies ? or does not appear at all......I think it is because the Win2k admin password (which was used to install the software) has been changed. I think this has caused the CW2000 daemon manager service not to start. (it won't start manually either)
Does anyone know a way to solve this problem??
mferhai
i have the same problem.
Could you please if you have resolved this problem ??
Thank you for your response
