08-21-2003 11:56 PM - edited 03-02-2019 09:48 AM
I have r5 configured to watch network 200.0.0.2/32 which is the loopback address of the other isdn router, r2. The primary link between the two routers is a frame relay network. The routing protocol is eigrp. The problem is that r5 will always dial to r2 and istall the route over isdn link even if the primary link is up. The " debug ip routing" command shows me that the router does this because the route to r2's loopback interface has a lower admin distance over isdn as you can see from the output below. What could be the problem?
r5#show ip route
Codes: C - connected, S - static, I - IGRP, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2, E - EGP
i - IS-IS, L1 - IS-IS level-1, L2 - IS-IS level-2, ia - IS-IS inter area
* - candidate default, U - per-user static route, o - ODR
P - periodic downloaded static route
Gateway of last resort is not set
200.0.0.0/32 is subnetted, 2 subnets
C 200.0.0.2 is directly connected, BRI0
C 200.0.0.5 is directly connected, Loopback0
150.50.0.0/16 is variably subnetted, 2 subnets, 2 masks
C 150.50.9.0/26 is directly connected, BRI0
C 150.50.100.0/27 is directly connected, Serial0
r5#clear int bri 0
r5#
04:14:21: %ISDN-6-DISCONNECT: Interface BRI0:1 disconnected from 8358661 r2, call lasted 1381 seconds
04:14:21: %LINK-3-UPDOWN: Interface BRI0:1, changed state to down
04:14:22: %LINK-3-UPDOWN: Interface Virtual-Access1, changed state to down
r5#
04:14:22: RT: del 200.0.0.2/32 via 0.0.0.0, connected metric [0/0]
04:14:22: RT: delete subnet route to 200.0.0.2/32
04:14:22: RT: add 200.0.0.2/32 via 150.50.9.2, eigrp metric [100/40640000]
04:14:22: RT: del 200.0.0.2/32 via 150.50.9.2, eigrp metric [100/40640000]
04:14:22: RT: add 200.0.0.2/32 via 150.50.100.2, eigrp metric [100/2297856]
04:14:22: %LINEPROTO-5-UPDOWN: Line protocol on Interface BRI0:1, changed state to down
04:14:23: %LINEPROTO-5-UPDOWN: Line protocol on Interface Virtual-Access1, changed state to down
r5#
04:14:23: is_up: 1 state: 4 sub state: 1 line: 0
r5#show ip route
D 200.0.0.2 [100/2297856] via 150.50.100.2, 00:00:07, Serial0
r5#
04:15:22: %LINK-3-UPDOWN: Interface BRI0:1, changed state to up
r5#
04:15:24: %LINK-3-UPDOWN: Interface Virtual-Access1, changed state to up
r5#
04:15:24: is_up: 1 state: 4 sub state: 1 line: 0
04:15:24: RT: closer admin distance for 200.0.0.2, flushing 1 routes
04:15:24: RT: add 200.0.0.2/32 via 0.0.0.0, connected metric [0/0]
r5#
04:15:25: %LINEPROTO-5-UPDOWN: Line protocol on Interface BRI0:1, changed state to up
04:15:25: %LINEPROTO-5-UPDOWN: Line protocol on Interface Virtual-Access1, changed state to up
r5#
04:15:28: %ISDN-6-CONNECT: Interface BRI0:1 is now connected to 8358661 r2
r5#
r5#show ip int brief
BRI0 150.50.9.5 YES NVRAM up up
BRI0:1 unassigned YES unset up up
BRI0:2 unassigned YES unset down down
Ethernet0 150.50.7.5 YES NVRAM administratively down down
Loopback0 200.0.0.5 YES NVRAM up up
Serial0 150.50.100.5 YES NVRAM up up
Serial1 unassigned YES NVRAM administratively down down
Virtual-Access1 unassigned YES TFTP up up
r5#
r5#show run
Building configuration...
Current configuration : 1721 bytes
version 12.1
no service single-slot-reload-enable
service timestamps debug uptime
service timestamps log uptime
hostname r5
logging rate-limit console 10 except errors
ip subnet-zero
no ip finger
no ip domain-lookup
isdn switch-type basic-ni
cns event-service server
interface Loopback0
ip address xxx.xxx.xx.5 255.255.255.255
interface Ethernet0
ip address xxx.xx.7.5 255.255.255.128
shutdown
interface Serial0
ip address 150.50.100.5 255.255.255.224
encapsulation frame-relay
frame-relay map ip 150.50.100.2 501 broadcast
frame-relay map ip 150.50.100.5 501
frame-relay map ip 150.50.100.6 501 broadcast
frame-relay lmi-type cisco
interface Serial1
no ip address
shutdown
interface BRI0
ip address 150.50.9.5 255.255.255.192
encapsulation ppp
dialer watch-disable 5
dialer map ip 200.0.0.2 name r2 broadcast 8358661
dialer map ip 150.50.9.2 name r2 broadcast 8358661
dialer watch-group 1
dialer-group 1
isdn spid1 0835866201 8358662
isdn spid2 0835866401 8358664
ppp multilink
router eigrp 100
passive-interface Loopback0
network 150.50.0.0
network 200.0.0.0
distance 100 0.0.0.0 255.255.255.255
distance 100 150.50.9.5 0.0.0.0
distance 100 150.50.9.2 0.0.0.0
no auto-summary
no eigrp log-neighbor-changes
ip kerberos source-interface any
ip classless
ip http server
map-class dialer myclass
access-list 101 deny eigrp any any
access-list 101 permit ip any any
dialer watch-list 1 ip 200.0.0.2 255.255.255.255
dialer-list 1 protocol ip list 101
alias exec br show ip interface brief
line con 0
exec-timeout 0 0
logging synchronous
transport input none
line aux 0
line vty 0 4
login
end
r5#
r5#show dialer
BRI0 - dialer type = ISDN
Dial String Successes Failures Last DNIS Last status
8358661 10 8 00:09:16 successful
0 incoming call(s) have been screened.
0 incoming call(s) rejected for callback.
BRI0:1 - dialer type = ISDN
Idle timer (120 secs), Fast idle timer (20 secs)
Wait for carrier (30 secs), Re-enable (15 secs)
Dialer state is multilink member
Dial reason: Dialing on watched route loss
Connected to 8358661 (r2)
BRI0:2 - dialer type = ISDN
Dialer state is idle
r5#
08-22-2003 04:55 AM
Your configuration includes both the dialer watch-group and the dialer-group. I don't believe that the dialer-group is necessary when you have a dialer-watch group. Try eliminating the dialer-group and see if the dial backup behavior acts as you expect.
Mark
09-04-2003 09:31 AM
dou you receive the watched route by serial link? If you do, the dial-back-up should not be triggered!!!
09-04-2003 09:43 AM
If the route being watched is seen through the serial link the dial-back-up should not be initiated. The problem when the metric through isdn is lower than normal link appears when the isdn must be disconnected ( when primary is up). If you use ospf you could use "ip ospf cost" under isdn interface to increase the metric or under the other interface to decrease the metric, so the metric on isdn to be the largest. If you want to use eigrp try to see if you can achieve the same thing by redistributing the route being watched with some metric....
Adi
08-22-2003 12:02 PM
EIGRP calculate is metric by default of Bandwidth + Delay.
EIGRP cannot determine the true bandwidth of a connection it relies on the user to configure this with the bandwidth command on the physical interface.
I see no bandwidth statement configured. This means that your two interfaces have relied on their defaults. So EIGRP is probably preferring the link with less delay. In this case it must be your ISDN link. Try manually setting bandwidth statements on your interfaces. You'll need your Serial link to 'show' a higher bandwidth than the ISDN.
08-28-2003 08:19 AM
I had issues running dialer watch with eigrp. What version of code are you running? Cisco states that dialer watch was not stable until 12.1(7) I believe. I ended up in 12.2 train for everything to be stable. It looks like dialer watch is not recognizing the valid route seen via eigrp.
Mark
09-05-2003 05:14 AM
I think using BRI int as backup will solve ur problem.
int s0
backup interface bri0
backup delay 20 30
Amit Shrivastava
India
