etherchannel config on 3750 daisy-chained switches
netman2k5
Beginner
Beginner
please someone help with the following situation: I got 3 each 3750-48 port switches daisy chained together. Console into switch 1 (master) and see all of other 2 switches. Following config works on switch 1:
interface range GigabitEthernet1/0/47 - 48
switchport mode trunk
switchport trunk encap dot1q
switchport trunk allow vlan all
channel-group 5 mode desirable
but similar config to interface Gi2/0/47 - 48 , it complains about the statement "channel-group 5 mode desirable". Got meesage saying that it should be on the same switch so I console into switch 2 but same problem. Am I missing something here ? thanks for all help.
2 REPLIES 2
glen.grant
Advisor
Advisor
Are you just trying to channel G2/0/47-48 ??? If so set up a second channel group such as 6 to feed those two . Don't know if there are restrictions of say creating an etherchannel across stacked switches but I almost think there is . Just try a different channel group , you have the same one on both setups.
Dear Sir,
Thank you for your help, I will try it tomorrow when I'm on site. Have a good evening.
netman2k5
