Is there some traffic annalists tool able to determinate how many E1/T1 should be used to connect LAN to LAN trough a dedicated circuit based up on the number of devices connected to each LAN network.
Any static chart will be difficult in the extreme to match to your individual enterprise, as traffic patterns will be unique. Utilize a monitoring tool and create a baseline for your network, this is the only accurate way to design.
Juan prueba son Netxray , pero si lo que necesitas es ver que trafico esta pasando por tu E1 creo con CiscoWorks 2000 / Surveyor
Saludos
