Hi all,
Has anyone successfully implemented epvn/mpls between asr1001 and asr9000. My test setup is following:
Two asr9000 connected to each other with few working bridge domains configured. Software is 6.7.2
Two asr1001 (Fuji 16.9.6) are bit connected to one asr 9000 and have one bridge domain configured that already exists and it is fully tested on asr9000.
Ospf in single area with loopback for ospf, mpls and bgp.
Asr1001 are RR clients and Asr9000 are RR with different cluster id.the problem i am having is that i can see all mac address form the bridge domain on all 4 routers. However, ping and arp work between hosts connected to asr1001 and hosts connected to asr9000 but hosts on asr1001 can't see nor ping hosts on asr9000.
Any suggestions?
can you draw the topology ?
