Extending Ethernet Connections
Randy Calderon
Hello Experts,
I was wondering if anyone here in the Cisco Support Community have successfully extended an ethernet network that handles VoIP traffic. If so, I'd like to know your recommendations. I need to extend two ethernet connections by no more than 400 feet. What type of ethernet extender device did you use and what media (fiber, coax, etc.) did you use to extend the ethernet connection? What are the possible disadvantages and/or issues I might face if I extend this VoIP ethernet connection?
Thank you very much for your time,
Randy C.
9 Replies 9
Philip D'Ath
Being over 100m you'll need to use fibre (coax is from the dark ages).  I would use switches with built in fibre ports.  Then you just need to buy SFPs.
What sort of switches are you using at the moment?
Hello Philip,
We have one Cisco 2960-X to be used on that site and I have a Cisco 3560-E that I use in the lab. This extension is only temporary as the site is being renovated. After the construction, this extension will go away.
Is it possible to purchase fiber cables that are already pre-terminated? I've never handled fiber cables before.
Thank you for your time,
Randy
This is a 120m fibre run.  Possibly - but I wouldn't do it.  Get a professional cabling company in, and get a proper cable put in.  If this single cable fails you'll loose the whole site that has been renovated.
Because the cost of labour is high and fibre is relatively cheap, I would get a pair of fibres installed so you can form a redundant link.
As long as both switches can take SFP's, you'll need to buy SFP's as well to plug the fibre into.
I was looking at Table 1 of http://www.cisco.com/c/en/us/products/collateral/interfaces-modules/gigabit-ethernet-gbic-sfp-modules/product_data_sheet0900aecd8033f885.html and I got thrown off and confused about multimode fiber limitation. Thanks for clarifying that.
I've reached out to a cabling company and asked to give me a quote for this job. I plan to use a GLC-SX-MM SFPs for both switches. For the Cisco 3560-E, I will use a "TwinGig Converter Module" together with the SFP. Does this seem like a sound game plan to you?
Thanks again,
Randy C.
FDDI grade fibre is from the dark ages.  You would only find it at old sites.  These days you should only be installing OM3 or OM4 fibre.
It would be great if you could rate my answer and mark it as correct if you think it has helped you.  :-)
400 feet would mean about 121 metres.  This distance is about the borderline to support multi-mode fibre (OM3).  I'd go for multi-mode fibre because:
1.  Multi-mode fibre optic cable is CHEAPER than single-mode;  and
2.  Multi-mode SFP/SFP+ is half the cost of single-mode variety.
Seriously, OM3 is no where near its limit at 121m at Gigabit speeds.
On the 2960-X you would use 1000BASE-SX.
The 1000BASE-SX SFP, compatible with the IEEE 802.3z 1000BASE-SX standard, operates on legacy 50 μm multimode fiber links up to 550 m
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages wha2tsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
An alternative to fiber, is to use to copper cables, each 200 feet, and join them with an inexpensive (dumb) switch.
I only mention this, as in a later post, you say this is for a temporary setup.
