testspa
Beginner
Failure cause is HP DMA on Serial E3 interface
I have a problem on router 7200 VXR, IOS 12.1(6) with Serial E3 Interface:
%MUESLIX-1-STOPFAIL: Mx serial, Serial2/0 Stop Failed at disable port
%MUESLIX-1-FAILURE_CAUSE: Serial2/0: descriptor dma excessive retry
Failure cause is HP DMA: : 0x00000000, 0x00000000
Could you help me?
1 REPLY 1
liviu.gheorghe
Participant
It's a software defect in 12.1(6). The following link indicates the upgrade path to fix the problem:
http://www.cisco.com/warp/public/770/fn18950.shtml
Cheers,
Liviu
