12-29-2013 12:08 AM - edited 03-03-2019 07:15 AM
Dear All,
I'm attaching a file containg a details for the prposed fiber cable o our site, the problem I have is , what is the meaning of Min. static/dynamic operating radius ? what is the diffrence between Static and dynamic bending?
The problem I have is the fiber cable will go vertically through out the building ( around 40 floor) and there is a certain floor with bending due to the changes of the location of the IT riser room ( shaft) , what is the max. bending allowed based on attached which will not affect the cable performance?
Mohamed
12-29-2013 03:27 AM
It will depend entirely on how thick your core is. The thicker the cable the "wider" the bend it will be.
Another thing, all fibre optic cable installer should know the parameters.
If this is a new run, make sure you put >10 metres of extra cable run at each end.
12-29-2013 04:14 AM
Thanks Leo,
will go for 24 core for each cable, not sure if you checked the attached specification file,
Is there any technical document for the standards in this regard from Cisco or any other?
the type of cables which will be used is supporting minumum radius of 7 cm what doeas it mean?
Mohamed
